My 2018 FC 25FB came with a blue ox antisway WD hitch and the ball is worn squeeking,
The shaft diameter on ball is 1 1/4
Took me time to get the right tools to work on it
Needs
3/4 socket wrench bought a 3/4 adapter for 1/2 drive
1 7/8 socket bought this from tractor supply
Bought a new stainless steel ball
Thought this might help others
Check torque spec to tighten 1 1/4” nut, about 430 lb-ft?
1/2” drive ain’t got enough oomph.
This is correct, at a minimum pick up a 3/4” Breaker bar and use that. Also pick up a 1” socket for the cams and use the breaker bar and the 1” socket instead of the stamped wrench they give you.
2023 Van Leigh Vilano 320GK
2019 International Serenity 27 FBQ “TC Escape” SOLD
2019 Ford F-350 Platinum
