02-10-2022, 09:32 AM
#21
Gilbert
Originally Posted by GettinAway
This is good to know. I admit, I’m a Toyota fanboy My 2012 still has a lot of years left in it, but I won’t be as concerned about that engine when it’s time to trade.
Same. I've never found myself on the side of the road with the brand. Wish they would just make a 3/4 ton. It'd sure make my decision easier. As it sits, it's choosing between the big three time bombs and which risk may be easier to deal with. Sad!
02-22-2022, 08:32 PM
#22
2019 25' Flying Cloud
Houston
More payload data points
02-23-2022, 06:40 AM
#23
2020 Globetrotter 25 FBT
2020 25' Globetrotter
Wildwood
, Missouri
You can always beef up the rear suspension and tires. Certainly changes how the truck handles the payload. “Does not change the door sticker.”
Keep Toyota reliability (if this engine proves durable in this application) and get towing ease.
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19’ Bambi, and (11) FC 23FB
02-23-2022, 06:45 AM
#24
Cambridge
, Ontario
I've observed at least one Tundra forum member who actually weighed his new 2022 properly and determined that his actual payload is almost 300 lbs more than what his door jam sticker states.
What I'd like to know is how Toyota can legally advertise a maximum payload of 1940 lbs for the 2022 Tundra then not manufacturer a model with a payload even close to that. The highest listed in their manual is 1580 lbs for an SR DC 2WD 8' bed.
Has anyone else noticed that Toyota uses different terminology depending on where the spec is shown?
The owner's manual uses the term 'Vehicle Capacity Weight' (and contains a lower amount). The vehicle ordering guide uses the term 'Payload' (and contains a higher amount). The door jam sticker doesn't use either term but the amounts appear to match those in the manual.
I believe that all of these terms have different definitions, meaning that the conditions under which they were determined is different.
All I care about is GVWR, and GCVWR (since I plan to tow), so just give me those numbers and the empty curb weight and let me do the math myself.
It would be nice to know what the actual payload would be for a 2022 Tundra that I want to order.
02-23-2022, 06:57 AM
#25
2015 20' Flying Cloud
Kingsport
, Tennessee
Er... the door jamb sticker states the payload... there is no weighing the truck and determining a different payload. A vehicle may be able to tolerate a higher amount of weight than the payload, but the payload is what is on the door jamb sticker.
-Leslie
WBCCI #1051
02-23-2022, 07:06 AM
#26
That door sticker is a conservative estimate, and the only way to determine the actual payload is to weigh the vehicle.
They can legally understand it, but they can't overstate it. I'm going through the same thing with my BMW. IIRC only the American manufacturers actually weigh the vehicle after it's complete. Others use a close estimate based on options and configuration. Weighing is the correct way to go.
02-23-2022, 07:07 AM
#27
Cambridge
, Ontario
Er...you're assuming the manufacturer applied the correct sticker. As we all know: Payload = GVWR - empty curb weight.
That Tundra forum owner would not be exceeding the GVWR for his 2022 Tundra if he loaded that extra 300 lbs in his truck.
Toyota is advertising a maximum payload of 1940 lbs and yet you can't actually buy a model with even close to that payload.
Toyota's vehicle order guide states much higher amounts than the owner's manual.
The door jam stickers appear to match the owner's manual.
Something fishy going on for the out-of-the-loop consumer.
02-23-2022, 07:27 AM
#28
Kingsport
, Tennessee
It may be a conservative payload stated on the jamb (when working in engineering, there is a tendency to have a factor of safety built in), but once that sticker is applied, that's the payload.
Yes, it's possible that they applied the wrong numbers on a sticker, but unless the manufacturer replaces the sticker, that sticker is stating the payload.
One may choose to ignore the payload, they can weigh it and calculate what they think the payload should be, but it's not changing the payload, it's willfully loading more than the payload. Maybe safely, but, it's still ignoring it.
-Leslie
WBCCI #1051
02-23-2022, 07:55 AM
#29
Im not ignoring payload, I’m finding it. I prefer not to leave capacity on the table.
That sticker is an estimate and not legally binding unless you’re a commercial hauler.
It’s also possible to overload the vehicle without going over payload.
Payload is one number out of many needed to tow safely. The most accurate way to find payload is to weigh the vehicle.
#30
Cambridge
, Ontario
YDY. I'd prefer that this thread not devolve in to yet another payload debate.
My way more pressing matter is the apparent discrepancy between payload amounts stated in different reference material supplied by Toyota.
02-23-2022, 09:32 AM
#31
2021 25' Flying Cloud
berlin
, Maryland
Why is it that people want a truck that isn't built for towing to use as a tow vehicle. There are trucks built from the ground to be used for towing.
02-23-2022, 09:42 AM
#32
Cambridge
, Ontario
To which truck are you referring?
02-23-2022, 09:48 AM
#33
berlin
, Maryland
There are many. I was not referring to any particular brand or model. Just stating that some are made to tow and some aren't.
02-23-2022, 09:56 AM
#34
Cambridge
, Ontario
Oh, OK. This thread is about the 2022 Tundra.
10-10-2022, 04:26 AM
#35
2011 27 FB International
East Coast
, Newfoundland
Anyone towing with a '22 Tundra yet?
Traded my 2015 Limited 5.7l and took delivery of a Platinum 1794 (non-hybrid) last week.
I’ve towed my 2012 27FB about 500 miles so far with the new truck. First impressions?
1. The interior is far better than before. The seats are great and comfortable. The towing setup is detailed and the information presented on the dash is great - I can see my brake boost as it is applied.
2. The twin turbo pulls fine. I can set the radar cruise and the engine both accelerates and brakes to control speed. It even uses the actual brakes when the engine is not enough.
3. The tow mirrors are better than the last ones. Field of vision is better.
4. I’m going to need airbags in the back. Too much porpoising for my taste. My hitch is the Reese dual cam straight line.
5. I don’t see the advantage of the hybrid. That little battery will give a torque boost for sure, but not for long. I don’t think it would be of any benefit going up long hills. I say this from my point of view as I own and have driven an Audi e-tron for the last two years. As for the Tundra I’d rather have the under seat storage.
This is just my opinion, FWIW. Hold your criticisms - I spent a grand total of $4 (Canadian) in repairs on my last Tundra in 7 years. This is my third Tundra and I’m not changing back to other brands again. I’m also not interested in a 3/4 ton. I manage my payload within the door sticker and I weigh it to confirm.
[AIR# 55762 TAC# NFL-1
10-10-2022, 05:25 AM
#36
GLCMRANGER - Sue
2016 25' International
Littlestown
, Pennsylvania
I also have a 2022 Tundra 1794. I've leaving on a trip this week.... Having said that, did you try using the Electronically Modulated Air Suspension to raise the truck bed? Did you put the Height Control Switch to HIGH? Sorry I can't give you feedback yet...
thanks.
10-10-2022, 08:23 AM
#37
2019 22' Sport
Port Coquitlam
, British Columbia
We just traded our Ridgeline in on a 2022 Limited Crew TRD. The Ridgeline was nice and smooth overall but sometimes it felt a bit small for our little 22FB. Our trailer is quite light and only 500 lbs on the tongue when it is full of stuff. Going to test it out at the end of the month on our first trip with the revised combo.
Peter.
"Live Long and Prosper \\//" - Spock
10-11-2022, 07:45 AM
#38
Wildwood
, Missouri
Glad to see some of the 22s are getting out there and pulling airstreams. Please keep posting results. I have zero interest in getting any other truck than a Toyota. Creeping up on 160,000 mi on my 2012 DC 4x4. Still runs like new. Hopefully the airbag system will compensate for the sag. I went by an F-250 yesterday that had horrible sag. I imagine he needed his WDH set up better. All manufacturers are trying to improve the ride in their trucks.
2020 25GT FBT
10-23-2022, 09:01 AM
#39
2019 22' Sport
Port Coquitlam
, British Columbia
Got the Trailer and WDH dialled in and ready for our first trip with the Tundra this week!
Peter.
10-31-2022, 08:27 AM
#40
2019 22' Sport
Port Coquitlam
, British Columbia
Got a chance to tow with the Tundra and it was a solid ride. The Tundra pulled up some steep hills with power to spare and we tried out the descent control which shifted down automatically to maintain the speed without braking. This braking feature uses the engine to maintain the speed. Cruising along, the truck felt in control all the time. Keep in mind that we have a smaller trailer so we aren't pushing the limits. The built in towing features no this truck make it easy to hook up and go. Ours is a "Limited" trim and has 2 tow modes and a built in brake controller.
Peter.
