Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 06-22-2019, 05:09 AM   #1
2000 30' Excella
Toledo , Ohio
Airstream 30' and Pro Pride P3
Who tows a 30' with a P3 please tell me your setup
Thanks Les Grace
woodfox45 is offline   Reply With Quote
Old 06-22-2019, 05:17 AM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Thanks Les Grace
No P3 but I’m doing a Ram Diesel 2500 with blue OX and a classic 30. No problems. Tows like a dream.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 06-22-2019, 06:45 AM   #3
2019 30' Classic
Belen , New Mexico
2006 Dodge Ram 2500 5.7L Hemi
All lights have been converted to LEDs (headlightrevolution.com)
Pioneer AVIC-W8500NEX navigation computer
Rocktamers with the "Airstream" (from the airstream store.)
Oldtown 17' Penobscot Canoe
Thule roof rack
2 Pedago Platinum Interceptor E-bikes
Thule Folding Wing hitch bike carrier in the back of the truck (for carying bikes when at camp)
Homemade Fiamma style bike rack on the rear to hold 100lbs of bike.
The whole rig comes in at 17205 lbs, 30' Classic is 9640 lbs with 920lbs tongue weight.
The only thing missing in this photo is the two Pedago E-bikes hanging off of the rear of the 30' classic.
A side benefit of the PP is that there is enough clearance between the trailer and the truck to fully open the large hatch to access the contents of the ARE topper. Without that, I can only access through the walk-in door because the hatch hits the trailer jack. In the configuration shown, there isn't any access problems at all.
The truck also has aftermarket air suspension. To set the system up, I leveled the trailer and set the hitch height for the trailer coupler. The manual shows setting it up for the typical loading sag, but with the auto-leveling air bags, there is no sag. What you measure is what you get. I also measured the top of the front fender to the ground (34.5"). I then hook the trailer up, let the auto-leveler raise the back end back up and then crank the hitch jacks until the front fender is back to 34.5". Cat scales show that using that method puts the front axle weight back to within 100lbs of what the truck runs with normally.
Driving it is a dream. It's like running on rails with no major movement unless I want it to move. You have to be careful though. It drives so well, the temptation is to relax and drive one handed (caught my wife with only a thumb and two fingers on the steering wheel this last trip.)
Glad I spent the money on the hitch.
The next project is a 3" lift kit for the TT because there isn't enough clearance on the rear to get into most gas stations around here.
ID:	344081   Click image for larger version
Ephraim is offline   Reply With Quote
Old 06-23-2019, 04:34 PM   #4
2000 30' Excella
Toledo , Ohio
I guess I should have added with a GM 2500 HD to my post wondering about how many washers and what height on the jacks .
Thanks for the replies
Old 06-23-2019, 05:05 PM   #5
jaybauman's Avatar
2021 33FB Classic
2019 30' Flying Cloud
Katy , Texas
Hi WF
I tow a 2019 Flying Cloud 30 Bunkhouse with a 2015 GMC Duramax. Here are a few pics showing washers and stinger/drawbar setup. Colonial Airstream recommended 5.5" on the jacks, but after a few trips to the CAT scales and some banter with Sean Woodruff @ Propride, I now ride with 7" on the jacks.
Good luck with your setup!
2021 Classic 33
2020 GMC 3500HD Duramax AT4
ProPride 3P
jaybauman is offline   Reply With Quote
Old 06-23-2019, 05:20 PM   #6
2019 30' Classic
Belen , New Mexico
I have two washers on my stinger. I'm running 7.75" on my jacks with 1400lb bars.
7.75" puts the front axle weight back to within 100lbs of it's original weight with the Classic 30 (~900lbs tongue weight).
Old 06-24-2019, 07:37 AM   #7
2000 30' Excella
Toledo , Ohio
Originally Posted by jaybauman View Post
Hi WF
Thanks for the reply , I bought this hitch used and first camping trip last week 2 washers and 6" on the jacks on the way with a full tank of fresh water . front end of truck seemed to wander a little no sway problems though . On the way home empty water tank and 5 1/2" on jacks it towed about the same as before . I haven't been to a Cat scale yet just measured fender heights and I did have the front down about to 1/2" below unloaded height .
Pro Pride and Hensley Questions Pat Cassity Hitches, Couplers & Balls 41 09-21-2017 04:55 PM
Pro Pride or Hensley with F350 4X4 Crew Cab vetdr Hitches, Couplers & Balls 20 04-01-2012 10:24 PM
Pro Pride Arrived Today! AirHeadRik Hitches, Couplers & Balls 3 12-03-2010 07:18 AM
First Pro Pride tow Aviator Hitches, Couplers & Balls 3 06-06-2010 10:34 PM
Pro pride hitch/weight distribution question dkottum Hitches, Couplers & Balls 19 03-03-2010 09:42 PM
