I thought that I posted these questions earlier but it appears not.
1-For my 2018 Tundra TV, are Timbren Suspension kits recommended?
2- Will 16 rims/wheels fit a 93 21 ft
Sovereign? A visual inspection of clearance with the existing 15 inch rims looks tight between the dual tires and in the front and back of the wheel well. .
3. If I stick with the 15 inch rims are 10 ply trailer tires a good choice.
3. I would like to lift this by 3 inches so that I can use it on the back roads of the Great North Maine Woods but both Airstream and Dexter Axles were of no help.
Airstream suggested that in 93 axles were made by a company that is now out of business. When I called Dexter they said look for the stamped serial number on the Axles. I found what looked to be a plate in the front left of the axle that could accommodate a serial number but nothing was legible.
Thanks in advance!
