RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 01-17-2021, 09:41 AM   #1
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
7 Way Connection Observations
Folks,
Many threads and posts have dealt with loss of connection between the TV 7 way receptacle and the AS 7 way plug. Comments to fix the connection have included bungee cords, wrapping tape around the plug housing and other approaches. These observations are for the plug to receptacle electrical connections only.
I have a collection of new plugs and receptacles and put them on the bench to examine the connection system. Plugs included the original Bargman "V" style, flat blade plugs from Pollak believed to be a 12-702, Hopkins 48510 and an off-brand generic. The Bargman was in poor condition and would not even plug in to any receptacle. The other three plugs were examined and one measurable observation was readily apparent. The distance between the flat blades, inside to inside. See Ref. 1. The Hopkins 48510 measured .910" a second 48510 was measured at .915 between two opposing flats. The Pollak .980" and generic .990".
Each was inserted by hand plug only to receptacle only, no housings to interfere with the fitment of the contacts to blades to feel the force to insert and disconnect. Then an adjustable wrench was set to the measured gap and then test fitted on the receptacle. The .910" gap compressed the "V" and made a firm purchase on it, even holding it firmly for the picture. See Ref. 2. The same connection test was made with a .990" gap. It would not hold the receptacle and it made contact on a slant, see Ref. 3. It noticeably took more pull to separate the tighter .910" than the .990" from the receptacle.
My observation is that the tighter plug blade compressed the receptacle plug V and visually makes a larger surface for the electrical connection.
The next observation was inserting the various assembled plugs into my 2005 Dodge Ram original receptacle which was made by Pollak and feeling the apparent fitment force and checking the depth of insertion. The fitment feel is subjective, not measured. The .910" required more force to insert and remove. The depth of insertion is an easy one that you can check with a Sharpie or a pencil. Place the plug into the receptacle stopping at initial contact but do not fully insert, mark the side of the plug relative to the receptacle. Now insert and mark the plug again. Remove the plug and observe the insertion depth. Is it at least 3/8"? See Ref. 4.
I have had the Pollak style metal housing plug on my AS for several years and it has worked every time. I likely will be looking at installing the Hopkins 48510. It does have an unusual internal frame that the wires must go around to make the connection.
These are observations from an owner not based on any standards or manufacturers data. Check your connection terminals and review for repairs. And many modern TVs now have a plug and play type receptacle. It only took removing four screws and one connection if I needed to replace it. Check local auto parts stores, I bet they have them in stock.
This thread https://www.airforums.com/forums/f23...on-193473.html post 6 by martyw has an informative link to a 7 way connection discussion.
This important connection provides power to the brake system, brake lights, turn signals, marker lights and the charge line. It needs to do its job, every time you plug it in.
My buddy Tom, AKA Stremn will post my pics of these observations.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 01-17-2021, 09:46 AM   #2
STREMN's Avatar
2008 30' Classic S/O
Hampton Beach , New Hampshire
Images from Gary -
ID:	387095 Click image for larger version
ID:	387097 Click image for larger version
ID:	387099 Click image for larger version
- Tom and Wendy - AirSTREMN from New Hampshire -
- 2008 30' Classic S/O - S/OS #025 - Riding on 16" Wheels and Tires -
- Live Free or Die -
STREMN is offline   Reply With Quote
Old 01-17-2021, 10:02 AM   #3
batman's Avatar
1964 22' Safari
modesto , California
Poor connectivity! Point's well taken.
That is why I decided to go with the Heavy Duty commercial round pin style 7-way. Plus added security that not every one has these. If you are going to do it, do it right. My friend owns Burns Tractor Trailer, I got mine from him. This is similar. Check out the connections!
https://www.etrailer.com/Wiring/Poll...YaArOgEALw_wcB
-Dennis
batman is offline   Reply With Quote
Foil insulation - observations, tips and tricks malconium General Interior Topics 103 08-05-2015 03:51 PM
Used Airstream Market Observations Lahontancut Dollars & Cents 31 05-01-2010 07:12 PM
tow practice and other observations nettepdx Our Community 15 11-16-2004 12:18 AM
Axle observations till Axles 13 10-19-2004 11:13 AM
