Old 03-17-2024, 06:17 PM   #1
2024 28' Flying Cloud
Jackson , New Jersey
28RBT Tongue Weights
For folks that have weighed their tongues, what weights are you guys ringing up? I知 asking not b/c I知 concerned about my truck being able to take the weight (it can). I知 wondering actually if some of these 28RBTs are tongue LIGHT?
Looking closer at the 28RBT, it would seem to be weight biased towards the rear as that is where the majority of the storage lockers are and also the 2nd AC is mounted aft of the axles given the bedroom location.
Thoughts?
2023 F250 Lariat Supercab SB 4x4 7.3l 3.73 148 WB
Ordered: 2024 FC 28RBT, currently at the dealer !
S1njin is offline   Reply With Quote
Old 03-17-2024, 07:01 PM   #2
Waitsfield , VT
Thoughts?
We have a 2019 FC28 RBT I have weighed the tongue at exactly 1,000lbs. using a tongue weight scale and also confirmed at the CAT scale. hope that helps
artie2908 is offline   Reply With Quote
Old 03-17-2024, 08:19 PM   #3
Ty !
Old 03-17-2024, 08:31 PM   #4
2017 28' International
Jim Falls , Wisconsin
I have a 28 Rear Bedroom and tongue weight is about 1,000 lbs when loaded. The advantage of the rear bedroom is that most of the storage is at the rear of the Airstream. It starts out with a heavier tongue weight than front bedrooms since the kitchen etc is toward the front. But as you load for travel etc it balances out. I believe the manual wants that tongue weight around 1,000lbs. Some go higher. I try to keep the weight on my rear at around 1200lbs when my WDH and everything is taken into consideration.
If you have a 3/4 ton you won稚 have any problems with tongue weight. Just remember you are better off being tongue heavy than tongue light while towing (less sway). Don稚 pack too much in the back. To find out how much that can change, I have a tongue scale then take something that weighs 80lbs and move it around the trailer to see how it affects tongue weight. It does make a difference.
Daquenzer is offline   Reply With Quote
Old 04-02-2024, 09:18 PM   #5
Thiss's Avatar
1971 27' Overlander
2023 28' Flying Cloud
Monmouth , Oregon
I weighed our 2023 and got a tongue weight of 1,300lb with water
Thiss is offline   Reply With Quote
Old 04-03-2024, 07:14 AM   #6
2019 28' Flying Cloud
Broward , Florida
Mine comes in at 900 lbs, and it hardly changes no matter how I load it. How do you get 1300 lbs?
Andy543 is offline   Reply With Quote
Old 04-03-2024, 08:14 PM   #7
Thiss's Avatar
1971 27' Overlander
Monmouth , Oregon
With no weight distribution, I weighed the rear axle with trailer and without trailer and subtracted the difference.
With weight distribution I am running at 800lb of tongue weight.
Are you seeing something in my numbers that I am missing? Always open to helpful critiques.
Attachment is easier to read if opened.
Old 04-04-2024, 06:09 AM   #8
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
The trailer has to be about level to get an accurate tongue weight. The WD bars shift some force back to the trailer axles. Tongue weight is defined with the trailer sitting level and no WD engaged.
Old 04-04-2024, 07:35 AM   #9
Thiss's Avatar
1971 27' Overlander
Monmouth , Oregon
Good to know. It痴 sitting eyeball level on the ball, but not leveled level. Maybe I should try the bathroom scale method?
How is WD effecting the number for you all coming in at 900lb?
Share Your Real World Tongue Weights & Trailer Weights BoldAdventure Towing, Tow Vehicles & Hitches 184 07-28-2020 03:15 PM
Question about tongue weights bikechuck Towing, Tow Vehicles & Hitches 11 11-18-2016 03:11 PM
Real world tongue (hitch) weights kb0zke Towing, Tow Vehicles & Hitches 20 04-17-2016 09:56 AM
Can you trust Tongue weights provided by Airstream? Thiatt55 Towing, Tow Vehicles & Hitches 35 04-06-2016 10:23 AM
Different Tongue Weights same size trailers 28' vs 27' Vitaminsea Towing, Tow Vehicles & Hitches 28 03-06-2014 07:56 AM
