We just purchased a 2003 Safari AS 25' A (Twin). We want to remove the couch and put in two recliners with the fold out table moved from the side to the middle of the chairs. Two Issues I see, one is the
12V switch box on the left side under the couch, facing the front of the trailer. It appears to have enough wire length to move it to the center and let the table sit over it. Have not done that yet.
Issue two, the recliners will need to be anchored to the floor. We are going to remove the existing carpet and put down a wood laminate. The chairs would need some sort of anchor bolt. Do these bolts need to go all the way through the floor? This is the part I am most concerned about.
Has anyone done this type of conversion?
Many thanks, Jim (Central Oregon)
