04-27-2003, 09:41 PM
Tank level indicator panel
Hi gang,
Just back from a mini-vacation on the Sonoma Coast. The new six sleeper is working out great for the 4 of us.
One annoying issue is the intermittant readings from the tank level panel. The gray and fresh water indicator LEDs would sometimes not light up, or light up for an instant and go black. The black water tank indicator light also misbehaved a time or two. The battery indicator light always worked correctly. Only new variable during this trip is using a generator to refresh the batteries. Any ideas? I prefer to fix things myself, when feasible. (The dealer is about 150 miles away).
Thanks in advance.
Mike
04-27-2003, 09:53 PM
Contributing Member
Austin (Hays County)
Tank Indicators
I find that I get flaky readings for the tanks after the trailer has been unused for a couple of weeks. After I tow it, the indicators settle down. I have been wondering whether it is condensation after sitting unused.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
04-27-2003, 10:02 PM
Hi John,
It could be a moisture issue, come to think of it. There was a lot of rain over the past days and we brought a lot of it inside with the coats and damp shoes. Every morning the windows were covered in condensation. I'll check it out after things dry out here.
Regards,
Mike
04-28-2003, 05:46 AM
Mike,
I wouldn't depend on the indicator lights to be very accurate, especially when determining battery condition. The difference between a fully charged battery and a half charged battery is something like 0.5 volts. Batteries need to be checked with a hydrometer, or at least with a digital multimeter with the battery at rest.
None of my indicator lights are very accdurate. I just cleaned and completely drained both holding tanks and the lights show them between 1/3 and1/2 full.
Les
04-28-2003, 07:50 AM
Aluminut
2004 25' Safari
Mine too are a bit flakey. Mine don't seem as bad as yours, but I flushed out the tanks pretty good (fill and dump, fill and dump) a few times. I get some flickers when the levels are between ranges, but I consider that normal since the sensor might be just barely touched.
My readouts however never go totally out if there measureable stuff in the tanks and the indicator lights were lit.
eric
05-07-2003, 07:38 AM
guage adjustments
My 2001 Safari's tank guages worked the first time out and after the 3-4 outing were useless. They must get dirty and need readjustment. With all your tanks empty and trailer level. Take the panel off the wall. You might have to then take the circuit board off the panel and you will see the little switches. With a small screw driver adjust so the light just go out. Fixed!
Warren
2001 Safari 27 rear queen
awnings all around & 150w solar
Web Page: https://w9det.bizland.com
05-07-2003, 09:54 AM
Thanks for the tip. I will check that approach out since it is clear now that humidity is not a factor. We had a few days of sunshine in the past week and the panel is still not registering anything at all for any of the tanks.
Mike
11-07-2003, 09:27 AM
1978 31' Sovereign
Texas Airstream Harbor
, Zavalla, in the Deep East Texas Piney Woods on Lake Sam Rayburn
New Question - Physical Gray Tank Measurement
The potable tank is semi-clear plastic, and, with a few contortions, can be measured. The black tank may also be measured, no matter how unpleasant it is, via the toilet.
That leaves the gray water.
Anyone have any ideas as to how to get an actual physical measurement of the liquid level in the tank (other than to wait until it backs up into the shower)?
I feel my indicator lights are measuring high, but I guess I should be happy that they are working at all.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
04-16-2021, 09:55 PM
2001 25' Safari
Phoenix
We have a similar issue, not exactly the same but ... The water pump switch is working fine even though it's on the same panel as Levels. BUT the levels indicator switch is frozen, won't move, won't turn on. This is the original panel and we're on the road. It was fine yesterday, then today the switch for levels won't budge. Thanks in advance for any ideas.
