Problem fixed
Good news. Working with Airstream techs by phone, Parkview RV was told to remove the rear wall electrical outlet box and pull out as much of the TV antenna cable as possible. When they did this, they discovered that the Airstream factory had neglected to connect the splice the feeds signal to the bedroom antenna outlet! Another example of faultering quality control in Jackson Center! Parkview connected the splice and all works fine now. Problem solved.
Lew Brodsky
Springfield, VA
