Old 01-30-2019, 03:31 PM   #1
CruiserGa
Bmccorm's Avatar
2004 25' Safari
Gainesville , Georgia
Charging Question
If i hook up a battery tender (fancy trickle charger) do i need to disconnect the battery cables? Will it cause any harm upstream?
Bmccorm is offline   Reply With Quote
Old 01-30-2019, 04:04 PM   #2
2007 22' International CCD
It would cause no harm, but you need to be sure it can deliver enough current (amps) to compensate for the usual parasitic loads in an Airstream.
These loads are stuff like the Propane Detector, and the Sub-woofer speaker, as two examples that come immediately to mind.
I use DelTran battery tenders for a lot of standby charging applications. Haven't had an issue yet, unless I forget to connect it to the battery...
Old 01-30-2019, 06:19 PM   #3
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
No it will not...is good
USB Charging Ports not charging WkendWarrior Electrical - Systems, Generators, Batteries & Solar 29 09-08-2018 08:12 PM
Battery charging question jhenschen Batteries, Univolts, Converters & Inverters 9 07-24-2010 12:04 AM
Batteries..basic charging question Delaware Batteries, Univolts, Converters & Inverters 3 11-16-2009 01:19 AM
Question re: battery charging Lani Batteries, Univolts, Converters & Inverters 11 07-12-2009 10:02 PM
Solar Charging System Question Mod-Streamer Generators & Solar Power 1 01-16-2006 10:33 PM
