Old 08-09-2019, 12:17 PM   #21
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
If you are used to towing a 25' and then get a 30', when you think you've reached your destination you'll still have 5 feet to go.
2019 Ford Expedition Platinum
Old 08-09-2019, 12:27 PM   #22
2004 30' Classic
California , MD
Originally Posted by wayne&sam View Post
if you are used to towing a 25' and then get a 30', when you think you've reached your destination you'll still have 5 feet to go.
too funny!
cru-in is offline   Reply With Quote
Old 08-09-2019, 12:54 PM   #23
PCJ
2018 30' Classic
Eden Prairie , Minnesota
We have no problem with our Classic 30, even if it's a little longer. Sometimes I wish it was smaller when we get into a tight back-in site. However now that we're full time I would not shorten it. We also pull with a 1 ton Chev diesel
PCJ is offline   Reply With Quote
Old 08-09-2019, 03:20 PM   #24
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
We went from a 25’ International Serenity to the 30’ Classic twin beds. Love it! As stated by others, only differences in towing is that you have to get used to the angle of departure (I drag the bumper savers on a hill hairpin turn to get to my house) and making a wider swing when executing a 90 degree turn to allow enough room for the trailer wheels to not cut the corner. I just now backed my 30 into a state campground site that I would have had trouble backing my 25 into. The site is long enough but the approach was miserable so now I know why they said “not recommended for trailers over 24’..... ;-)
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 08-09-2019, 04:22 PM   #25
Rgentum's Avatar
2016 27' Flying Cloud
Olympia , Washington
We live in the NW and prefer state & nat'l campgrounds over private ones. What I can say after 36K miles with our 27 FB is that I believe we've gotten into a whole lot of camp sites where I seriously doubt we could have done so with a 30. The 27 remains "our great compromise, a la les trois ours."
Richard Wills, Olympia, WA --- WBCCI 8873, WL7Z
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
RIP "BigDog": M Harlequin Great Dane, 150 lb
"St. Rocco": M Black Great Dane, 150 lb
Rgentum is offline   Reply With Quote
Old 08-09-2019, 10:50 PM   #26
Lil Bear's Avatar
2019 30' Classic
Cary , North Carolina
We recently went from a 26U to a Classic 30 and feel no difference in terms of length. Both were towed with 2017 F250 6.7l diesel. The rear end does extend beyond the axels more so dragging needs to be monitored. We love the extra space inside and with the twin layout we also have more outside storage.
Lil Bear is offline   Reply With Quote
Old 08-13-2019, 06:38 PM   #27
2018 30' Classic
Jacksonville , Florida
We tow a 30 because the 27 was too small.
Overstreet is offline   Reply With Quote
Old 08-13-2019, 08:51 PM   #28
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Went from a 27' Safari to a 30' Classic Slide Out. Quite a big difference in towing due to the weight difference between the two trailers...., about 2,500 more lbs. Also required a bigger hitch to carry the 1,280 lb hitch weight of the Classic. Accordingly we also stepped up from a 1/2 Chevy van to a 3/4 ton GMC with a 9,990 lb towing capacity.
Nothing negative regarding the towing however. Classic just sits behind that van ignoring most passing vehicles and wind. I did obviously bulk up the hitch and tow vehicle to deal with what at the time was the heaviest trailer that Airstream ever built on a tandem axle.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 08-13-2019, 08:58 PM   #29
mikeinca's Avatar
2020 25' Globetrotter
Santa Rosa , California
We started with a 25' several years ago and "upgraded" to our current 30' Classic. We were seduced by the features, living space and ample storage in the 30 footer and there's no doubt it tows beautifully with the F250 diesel just going down the road. The simple fact of the matter, however, is that there are places we have wanted to go and things we have tried to do with the 30' that have been just about undoable.
It hasn't been a problem at all in RV parks and the like but we've been doing more boondocking lately. On a trip to Oregon last week our reserved site in a Forest Service campground was advertised to accommodate a 35' trailer. Unfortunately, because of the acute entry angle and numerous obstacles (trees, stumps, 6 foot boulders) it was a nightmare trying to wedge a 30' trailer into the site. By contrast, I would have been able to slide our old 25 footer right in.
It boils down to what you want to do and where you want to go with your RV. Some folks may never run into a problem for that reason and for them a 30' trailer is perfect. But to say that the extra 5 feet of length doesn't make any difference at all can be a bit misleading. We're seriously considering downsizing.
Mike
2020 25' Globetrotter Twin | 2024 GMC Sierra 2500HD Denali Ult. 4x4 Duramax
400Ah Battle Born lithium battery string | 580W solar (400W roof 180W portable)
mikeinca is offline   Reply With Quote
Old 08-14-2019, 09:25 AM   #30
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
There are a number of different 30' models. The Classic's are a bit heavier than some of the others. There are also a couple of different 25' models. You can almost double the amount of weight you are pulling going from 25' to 30'. Find a steep enough hill and a small enough engine ... you will notice the difference. Provided you up the TV a bit, even that isn't a really big deal. Put another way, you can get away with pulling a 25' with some "mid sized" SUV's. I would not want to try to pull my 30' Classic with one.
More important is picking the trailer that actually fits your needs. There are a *lot* of models in the 25 to 30' range. Figure out that part first. Go find a dealer with inventory on the lot and spend some time in all of them. Hours are the right measure here, not minutes. It's going to take a full day to "try on" everything.
Old 08-14-2019, 09:25 AM   #31
2019 25' Flying Cloud
Greeneville , Tennessee
We went from a 25' to a 30'. Straight line, no problem. Up hill, no problem. Down a curvy mountain road, BIG PROBLEM! I bought a bigger truck.
jimfa440 is offline   Reply With Quote
Old 08-14-2019, 11:08 AM   #32
2014 25' FB International
Estero , Florida
30 vs 25 tow.
We did this same upgrade about a year ago. We thought there would be a big difference but quite the contrary. Seems to be a better ride as well. Your turns and backins will need extra care. We love our 30!!!
Originally Posted by cru-in View Post
Hi Team,
Assuming one has the correct tow vehicle, does the extra 5 feet of a 30 versus a 25 make much difference in towing?
Looking to make a decision in the near-term so we would appreciate any inputs.
Dan
P
rest awhile is offline   Reply With Quote
Old 09-02-2019, 07:05 PM   #33
2012 30' Flying Cloud
Morongo Valley , California
Hi Team,
Dan
P
No.
Alan 117 is offline   Reply With Quote
LT versus ST tires on a trailer 91Excella Tires 18 08-29-2014 04:03 PM
Ford e350 Van versus Chevy Express 3500 for Towing sigv Tow Vehicles 10 01-21-2010 09:05 AM
Bambi Towing versus SOB DreamStream Towing, Tow Vehicles & Hitches 21 01-23-2004 12:51 PM
Hydraulic versus electric brakes jalewis Our Community 5 07-30-2003 08:49 PM
Airstreams: 1978 versus 1984 drboyd General Repair Forum 3 06-22-2003 06:07 PM
