Old 04-12-2020, 11:54 AM   #41
MaineStreamer's Avatar
2007 20' Safari
Old Orchard Beach , Maine
I have the same logistical situation. I simply don’t open the tailgate when the airstream is attached to the truck.
Marty Womer
Old Orchard Beach, Maine
Trailer name: Quarantina
MaineStreamer is offline   Reply With Quote
Old 04-12-2020, 01:23 PM   #42
2018 25' Flying Cloud
AURORA , Colorado
We had the same issue and bought an eTrailer receiver tube adapter. It extends the hitch so the AS is back about 6. Not only can we now get the tailgate down, but I now have enough room to step over the hitch without whacking my knee. And it makes turns easier.
MattsGal is offline   Reply With Quote
Old 04-12-2020, 01:28 PM   #43
High Point , North Carolina
My solution may not be yours as I have Blue ox WD hitch. It was set up by the dealer and my tailgate would hit the lift motor too. I noticed though that my setup was ever so slightly low at the ball so I moved it up one hole position. Made everything level, solved the tailgate issue and didn't affect towing at all.
Rfriebele is offline   Reply With Quote
Old 04-12-2020, 02:21 PM   #44
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Originally Posted by batman View Post
You should be able to rotate the head 45 degrees for clearance.
Dennis
Yes....And the open side of the chain hooks should face toward the rear.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"My sex life is like a Ferrari...I don't have a Ferrari."
Dino Longuini
Tahawus....🌥
Old 04-12-2020, 02:55 PM   #45
Ultraclassic's Avatar
2000 30' Excella
GTA , Ontario
Bob.
Why have the hooks face up and back?
Wouldn't it be safer to be pointed down
Tow Vehicle 2005 Ford F150 Lariat 367,000Kms 5.4L - 2012 Mercedes Benz GL350d - [not set up yet]
Ultraclassic is offline   Reply With Quote
Old 04-12-2020, 04:15 PM   #46
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
Correct!
sheriff1 is offline   Reply With Quote
Old 04-12-2020, 04:44 PM   #47
Originally Posted by Ultraclassic View Post
Bob.
Look closely at the latch up position.
If you do disconnect the open side faces up, the hook is pulled level with the closed side taking the tension.
Plus it's less likely that the hook could drop over bumps and when turning, because the spring that holds the safety latch cannot be bumped open. 👍
Molly Ivins
Dino Longuini
Tahawus....🌥
Old 04-12-2020, 09:25 PM   #48
2018 28' International
Fayetteville , Georgia
I did have to add one washer to the hitch head when I switched to a longer extension shank. When hitched I have 1 inch squat in the rear and 0 inch rise in the front. My F250 diesel and Serenity28 tow without any sway
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 04-12-2020, 11:23 PM   #49
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, the best match for a replacement shank, for my set up, was an 18" shank. I had a new hole drilled 2"s back. Later I had another hole drilled 2"s back and the excess end cut off. So my shank would fill the length of the receiver, the first time it was re-drilled I had 1" cut off of the end. When I had it re-drilled a second time, I had 2"s cut off of the end.
From hole to hole, if I could find a good match, a 14" shank would work. Mine ended up being 15"s because I wanted the shank to go all the way into the receiver.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-19-2020, 09:21 AM   #50
I have a Ram 2500 with ARE cap. Both have sliding windows that match up so that air from cab can pass to bed of truck. Just squeeze some foam roll insulation around the windows where cap and cab come together.
Bnbright62 is offline   Reply With Quote
Suburban: Clearance for Tailgate w/Airstream? redwoodguy Tow Vehicles 38 02-27-2019 05:31 PM
1969 Airstream - The Ultimate Tailgate Trailer eBay Watch Airstreams on eBay 1 09-13-2011 09:19 AM
1996 AIRSTREAM Land Yacht GEORGIA BULLDOG Tailgate eBay Watch Airstreams on eBay 0 03-31-2010 06:20 PM
1996 AIRSTREAM Land Yacht GEORGIA BULLDOG Tailgate eBay Watch Airstreams on eBay 0 03-17-2010 12:50 AM
1996 AIRSTREAM Land Yacht GEORGIA BULLDOG Tailgate eBay Watch Airstreams on eBay 0 03-05-2010 10:10 PM
