Old 09-01-2018, 11:51 AM   #21
1971 27' Overlander
Kansas City , Kansas
I used 1/16th Aluminum C channel for some of my bulkheads. It moulds to the wall very easily. When I have some time, I would like to polish them. The polished aluminum will make a nice transition between the white walls.
Using the channel also allows for flex which is important as per the post by skyguyscott
Shermy1987 is offline   Reply With Quote
Old 09-01-2018, 11:59 AM   #22
1971 27' Overlander
Old 09-01-2018, 10:40 PM   #23
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
This has been covered above to some degree, but the older Airstream trailers used face frame construction for cabinetry where the 'face' of the cabinet is 3/4" wood but the sides are 1/4" plywood. If you pay attention to fitting the panels to the frame and attaching the sides to the walls of the trailer, you get a simple, but strong, type of structure. The aluminum extrusions allow flexing, but they also can be used to distribute the load of an overhead cabinet when you want to hang the cabinet to the wall and ceiling. You can attach cabinet walls to the trailer walls with corner brackets but keep in mind that 1/4" plywood is flexible and that the aluminum extrusions coupled with good attachment to a face frame make for a pretty strong and firm wall. Just my $0.02 worth.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Adding panels on top of panels instead of replacing? The-Marco Ribs, Skins & Rivets 18 08-02-2014 04:53 PM
removing wall panels goose Ribs, Skins & Rivets 3 12-24-2010 04:20 PM
Back of interior wall panels zenman Upholstery, Blinds, Walls & Interior Finishes 5 09-22-2009 02:59 PM
Installing stainless steel wall panels mcneon Cabinets, Counter Tops & Furnishings 25 04-13-2007 04:48 PM
Peeling wall panels wacnstac Cabinets, Counter Tops & Furnishings 3 11-30-2006 08:11 PM
