Originally Posted by batman
Sorry for your loss.
Can you tow it? That would depend on how much sub-floor has been removed. Photos might be nice.
The shell is supported by the sub-floor witch is supported by the frame. So if too much sub-floor has been removed the shell could shift, buckle or worse while in transit.
Perhaps a portable welder?
You don't have to completely remove the shell to weld the frame or replace the sub-floor. There are several ways to Raise it and support it as you go or all at once.
-Dennis
Dennis
It has the typical rot at the back behind the shower and at the front under the water tank. I have not removed the subfloor yet and had thought about trying to replace the subfloor frame on due to restricted space and wanted to check before I went to far. I will have to look for a portable welder in my area being in a city they are rarer than in the country but there should be someone around
