Old 06-10-2024, 04:21 PM   #1
1977 Argosy 20
Carson City , Nevada
rebuilding closet
Hi All. I'm rebuilding the closet in my 20' minuet after a fire. (Long story)
I am going to reface the closet walls. One of the walls has come out of the trim piece that holds it to the outer wall. The problem seems to be that the plastic extrusion that actually holds the metal wall in has broken in a couple of places and I'll be darned if I can get it to stay in place. Is there somewhere to purchase this trim or the plastic extrusion?
Name:	Argosy Closet.jpg
Gaelic Girl is offline   Reply With Quote
Old 06-10-2024, 06:05 PM   #2
1966 22' Safari
Fredericksburg , Texas
I’m not familiar with a plastic extrusion. But then again, I don’t know much about anything after 1968 Airstream made RVs. Is the plastic extrusion considered to be what we call the ‘F-channel’. This channel allows a closet wooden wall to slip into the channel. This is pop riveted to the exterior metal wall. But, in your case there are a couple of ways to secure the wall to the exterior. Maybe someone will chime in with the information needed to locate that plastic extrusion. If possible post a picture of the wall connection. Good luck
Bubba L is offline   Reply With Quote
Old 06-10-2024, 06:09 PM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Is the gap 1/4" wide? I have that extrusion in aluminum from my 71. Globetrotter and the gap is for a 1/4 " thick panel.
Old 06-10-2024, 06:35 PM   #4
1966 22' Safari
The gap of the F-channel is 1/4”. In our 55 I went with 3/8” plywood which meant I had to use a router to cut the edge down to 1/4” to fit the channel.
Old 06-11-2024, 09:24 AM   #5
1976 Argosy 24
1961 28' Ambassador
1968 26' Overlander
Lakewood , Colorado
Hello, having replaced all the walls in our '76 Argosy I'm having trouble picturing a "plastic extrusion" being involved with the aluminum "channels" the walls insert into. Maybe a more specific picture would help. As Bubba and Aerowood have said, the metal channel is riveted to the inner skin. There are slightly different thickness panels which allow the wall to slide in easier or not so much. A true 1/4" panel can be very tight. I have "run" the whole channel with a chisel and hammer to re-size it for a better fit. Several years back the big box stores almost all sold a 1/4" Birch ply that was actually 6mm or maybe 7/32" but no one seems to have this post-pandemic. However, your challenge seems to be the channel staying in place? Like I said, maybe a better picture would help.
Good luck, Mark D
mrdes8 is offline   Reply With Quote
Old 06-11-2024, 09:43 AM   #6
1977 Argosy 20
Thanks all for your replies. I'll try to take a phot of the plastic part. Really don't want to rip out the whole thing….so I'm hoping to be able to utilize what is there.
Rebuilding Waste valves balrgn Waste Systems, Tanks & Totes 13 05-29-2024 02:56 PM
Rebuilding 65 rear end to modify or not to modify? tbrom Repairing/Replacing Floor &/or Frame 4 06-21-2007 08:53 AM
Rebuilding '68 Overlander Toilet Uberlanders Sinks, Showers & Toilets 5 04-17-2005 09:37 PM
Top ten things about rebuilding a new trailer campcollector 1997 - 2004 Bambi 2 02-27-2004 04:56 AM
Front floor area and rebuilding dresser jeanarlene 1969 - 1973 Safari 10 09-05-2002 11:11 AM
