I'm not clear where you are taking the "frame to frame" measurement from...'floor over the ceiling and back to the floor' or 'lengthwise down the trailer'.
Regardless,
when we did our trailer (see posts starting about #207) we used 2024-T3 and bought it by the foot in a continuous coil from
Airparts Inc.. As I recall, we ordered about 30'. If you want bigger than the 4'x12' sheets that the
6061-T6 comes in - you will need to go with the 2024-T3 which comes in 'up to 60" wide' x 'length by the foot'.
For comparison sake:
- 4'x12' sheet of 6061-T6 would cost $161.75 or $13.479 per lineal foot vs
- 4'x12' sheet of 2024-T3 cut from a coil would cost $16.75 per lineal foot or $201.00 per sheet
So 2024-T3
is more expensive - you just have to decide if you want 'one single sheet' or have a seam.
The exterior panels we replaced are polished (three trailers) so we
wanted 2024-T3, so the cost difference didn't matter for us there. We used the same on the the interior - even though we painted it with Zolatone - to get the longer length in a continuous sheet.
Shari
