Old 11-22-2017, 10:20 PM   #21
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
ID:	299646Click image for larger version
1973Argosy is offline   Reply With Quote
Old 11-22-2017, 10:23 PM   #22
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
ID:	299652Click image for larger version
ID:	299654Click image for larger version
ID:	299655Click image for larger version
ID:	299656Click image for larger version
ID:	299657Click image for larger version
ID:	299658Click image for larger version
ID:	299659Click image for larger version
Old 11-22-2017, 10:33 PM   #23
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
Originally Posted by luforia View Post
Thanks for answering, totally understand busy family time of year.
1. Yes, will set some $ aside for axle replacement. Good tip on board test, will try that on my 2008 AS. A supply center in CA offers fully built axles in 10Ē or 12Ē, do you know what size is on the 1974?
2. Thanks. Seems like there are all kinds of #s being thrown around, wasnít sure about where to look for definitive guide on such figures.
3. I bought 7round to 7flat adapter to avoid cutting/rewiring from trailer, hopefully adapter will solve that headache.
I love the beautiful white, goes well with your TV. Would love to see more of interior pics, likely just as amazing as exterior.
First things first, axles and wheels for me.
There ya go for some inside pics. Took all of these with the tablet I post from in hopes of straight pics. If I rotate them and save them rotated it still post them upside down??
There should be tags on your axles dead center on the front side normally. The information on tags is about the only way to really identify what axles your trailer has on it. From what I've read our early year Argosy's are a crap shoot of what was on hand at the time it was being built, and that goes for a number of systems.
Old 02-03-2018, 02:42 PM   #24
luforia's Avatar
2008 25' Safari FB SE
San Diego , California
Hi. So I ripped out my carpet and padding. Just noticed you have new floors. What did you end up using? Folks have been recommending Smartcore waterproof vinyl. How was the flooring process for you?
luforia is offline   Reply With Quote
Old 02-03-2018, 02:58 PM   #25
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
We put real wood down and love it. We glued it in but did use a nail or two in a few problematic areas. The installation was smooth and fairly easy. The floor has been down right at three years now and it still looks as good as it did when we installed it.
Old 02-03-2018, 10:04 PM   #26
luforia's Avatar
Thanks. So many people were afraid of real wood bc of weight concerns. I am not looking forward to all the angles and cuts and funny shaped edges, not sure how to make it fit perfectly.
Old 02-04-2018, 09:41 AM   #27
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
I have not put the trailer on the scales since the floor was put down, but all of the settings on the hitch remained the same. I also noticed no difference in towing.
Start from the center run and work your way out towards the bulkheads. We started in the bathroom, had the most special cuts, and worked our way forward. Once out of the bathroom things got a lot easier as there was room to maneuver.
Old 04-24-2018, 07:11 AM   #28
shiva-shantz's Avatar
1978 Argosy 24
Otisville , Michigan
Wow! Amazing job. Just quickly reading what your approach was, why the self etching primer and then then the fillable primer after? And why block sanding instead of using an electric sander? ( I assume that is hand sanding?). Did you leave the single stage poly as the only coat of that? No clear coat? What did you do for sealing the roof? Thanks for any info. I just posted in the roof restore section and wasnít aware this argosy section existed till after. Iíve got lots of ambition and not enough knowledge to do this just yet even though Iíve started prepping the roof already.
shiva-shantz is offline   Reply With Quote
New Paint Job israndy Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 11 09-18-2017 09:04 PM
Check out the new Paint Job!!! Peter Culp All Argosy Trailers 22 03-29-2017 11:26 AM
Uh Oh...Better Get (a new paint job) Dr.Theopolis Argosy Motorhomes 11 12-18-2009 09:42 AM
paint job codybear Upholstery, Blinds, Walls & Interior Finishes 26 05-16-2007 06:36 PM
Big Job turned into bigger JOB, need advice. lebolewis Waste Systems, Tanks & Totes 10 11-16-2006 05:28 AM
