Old 04-05-2020, 08:10 PM   #1
1979 Argosy Minuet 7.3 Metre
Madill , Oklahoma
Lack of floor support
Been busy since last time. Floor off our 79 argosy. My iigquestion is. At the bathroom end. The frame looks like has been cut itís doesnít feel like there enough metal there. If you stand on the frame it sinks down. Is this normal? Let me try with a picture.
Little city is offline   Reply With Quote
Old 04-07-2020, 09:34 AM   #2
Eric 26 Argo's Avatar
Knoxville , TN
My 77 Argosy is the same way. Your black water tank is siting over that area and the wood subfloor will tie it together. You wonít notice any real flex.
Eric 26 Argo is offline   Reply With Quote
Old 04-09-2020, 09:35 AM   #3
batman's Avatar
1964 22' Safari
modesto , California
Originally Posted by Little city View Post
Been busy since last time. Floor off our 79 argosy. My iigquestion is. At the bathroom end. The frame looks like has been cut it’s doesn’t feel like there enough metal there. If you stand on the frame it sinks down. Is this normal? Let me try with a picture.
If the frame moves independently of the shell It sounds like what you have is commonly called "REAR END SEPARATION". Very common on older AS.
If you replace the piece of plywood you cut out (your photo), without removing and replacing the entire piece under the "C-CHANNEL" you will have significant problems with frame separation going forward. Most people use the old sub-floor as a template. Once the entire piece has been removed.
You need to understand the way your trailer is built. It starts on the ground. The tires support the axle(s). The axle(s) support the frame. The frame and outriggers supports the plywood sub-floor. The sub-floor alone supports the shell via the "C-Channel".
So if you do not replace the plywood under the c-channel as one piece across the frame to the edges of the skin you have defeated the engineered supporting of the skin and will allow the frame to move independent of the shell. No bueno.
Check out the foto's and diagrams in these threads.
https://www.airforums.com/forums/f22...pan-69159.html
https://www.airforums.com/forums/f22...ff-191141.html
https://www.airforums.com/forums/f44...is-117570.html
Hope that helps.
-Dennis
batman is offline   Reply With Quote
Old 04-09-2020, 06:57 PM   #4
Madill , Oklahoma
Hope that helps.
-Dennis
Thanks a lot. The links helped also. We saved the floor for as much of a pattern as was usable. I see what you were talking about after I did extensive cleaning of the channel area. I feel ready in an unknowing way to tackle the floor. Thanks
Lack of insulation in floor of 22' CCD Upupandaway Buyer Guidelines 1 10-19-2012 03:36 PM
Friction.... or lack thereof JDL Off Topic Forum 4 01-19-2007 09:00 AM
Chat CANCELLED! Lack of interest! markdoane Off Topic Forum 1 05-23-2006 06:04 PM
Brakes.....or lack of. freeofecho Brakes & Brake Controllers 15 03-27-2006 08:58 AM
lack t v reception.... norbert Our Community 1 09-02-2003 09:05 AM
