Old 05-09-2018, 08:34 PM   #1
backroads73's Avatar
1973 Argosy 24
Grafton , Ohio
Floor work
I know this has been covered before, but I thought I would share it with pictures for everyone.I removed and replaced the front floor section, ours had the typical rot under the fresh water tank. The job took about 3 weeks(working on the weekends and a couple evenings in the middle of the week. I used 5/8" marine grade plywood, sealed with spar urethane( thats what I had left over from a different project) The pictures start with the groucho and water tank already removed. Thanks Dwayne
ID:	310553   Click image for larger version
ID:	310555   Click image for larger version
backroads73 is offline   Reply With Quote
Old 05-09-2018, 08:42 PM   #2
1973 Argosy 24
Grafton , Ohio
Floor work
More photos
ID:	310557   Click image for larger version
ID:	310559   Click image for larger version
ID:	310561   Click image for larger version
ID:	310563   Click image for larger version
ID:	310565   Click image for larger version
Old 05-09-2018, 08:49 PM   #3
1973 Argosy 24
Grafton , Ohio
Floor work
And more photos
ID:	310567   Click image for larger version
ID:	310569   Click image for larger version
ID:	310571   Click image for larger version
ID:	310573   Click image for larger version
ID:	310575   Click image for larger version
Old 05-09-2018, 08:52 PM   #4
1973 Argosy 24
Grafton , Ohio
Floor work
A couple more
ID:	310577   Click image for larger version
Old 05-09-2018, 09:06 PM   #5
dmbecke's Avatar
2014 25' FB Flying Cloud
Des Peres , Missouri
Looks great
dmbecke is offline   Reply With Quote
Old 05-10-2018, 10:16 PM   #6
1978 Argosy 27
Elk Rapids , Michigan
Nice work, how did you lift the shell?
matthewsx is offline   Reply With Quote
Old 05-11-2018, 04:31 AM   #7
1973 Argosy 24
Grafton , Ohio
Floor work
dembecke matthewsx , Thanks for the comments, I was lucky the aluminum was short enough on the curb side to slide the old one out then slide the new one in, pretty easy. I did not have to lift the shell. Dwayne
Work Platform for Roof Work Bubba John Roof 18 08-02-2015 09:16 AM
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 09:27 PM
Prep Work vs Finish Work Nolavalkyrie Vintage Kin 5 10-03-2013 03:11 PM
Cleaning becomes a little work becomes a lot of work - 1964 GlobeTrottin 1960 - 1964 Globetrotter 6 04-30-2011 10:36 AM
1960 Tradewind needs floor work and help! WcfdPiper Repairing/Replacing Floor &/or Frame 2 05-13-2009 07:34 PM
