Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 05-25-2011, 05:14 PM   #1
1977 Argosy 28
central square , New York
Broken plastic rear light? Argosy facade on rear
Hi...any ideas on a putty to piece/hold together the plastic rear light bar on a 77 argosy? Has broken in two and detached from body...looking for putty or glue ideas to fill cracks,remoldfrom from inside and re-attach.Is there a putty product any knows of that might hold it together? tnx...tom
tomzargosy is offline   Reply With Quote
Old 05-25-2011, 05:46 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Can you post some photos? Is the lense broken or just the back part?
Old 05-26-2011, 06:18 AM   #3
1977 Argosy 28
cracked rear light housing
Yea...whole housing is cracked and needs repair,is plastic and might be sealed with a high end putty type bondo or epoxy...just wondering if any others have fixed a plastic housing like on the back of the old argosy...tnx..
Old 05-26-2011, 06:55 AM   #4
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Southern , Wisconsin
I too have this issue...I considered removing it entirely but I want to keep the original look (not the leaks though). I haven't tackled it just yet. I am thinking to patch it from the inside with some type of bond/epoxy and smoothing the exterior to original shape.
All that is gold does not always glitter...those who wander not always are lost....
mnmhays is offline   Reply With Quote
Old 05-26-2011, 06:56 AM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Tail Lights
Do your taillights look like this?
Old 05-26-2011, 07:49 AM   #6
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
That is what mine looks like. I have several cracks and holes in the housing that hold the tail lights and Argosy emblem...
Old 05-26-2011, 08:24 AM   #7
RBolton's Avatar
Belington , West Virginia
Auto parts stores that carry body shop supplies usually carry adhesives that are good for this type of repair. 3M Structural Adhesive is one that comes to mind.
RBolton is offline   Reply With Quote
Old 05-26-2011, 10:06 AM   #8
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
I've wasted a lot of time just now writing a photo illustrated step-by -step example of how we removed the entire bezel when stripping the 1976 Argosy of it's original paint (1 photo); how we rebuilt the bezel using a BONDO Fiberglass Kit, it or similar available at auto supply stores (photos); how we replaced the bezel (photo); how we switched out the original lights for LEDs (photo) and what the trailer with repaired bezel, all in Black and Cooper White looks like now (photo)
When I try to post I get a message saying "exceeds your quota by 19.35 mb". I don't know why.
So the people that might benefit from the help are the losers, not me.
I'm just frustrated.
Sergei
http://www.airforums.com/forums/f227...tml#post182701
SmokelessJoe is offline   Reply With Quote
Old 06-11-2011, 10:24 PM   #9
VonLuck's Avatar
1973 Argosy 26
Burbank , California
I'm about to repair mine. There are a couple ways depending on how bad it's cracked. If you take it completely off you can lay some fiberglass down on the inside and pour some resin and spred around. Maybe at least two layers I'm thinking. Before you do this make sure you retain the shape and integrity. Then fiberglass bondo repair the outside and sand to finish.. Primer n paint.
If it's not that bad off just fiberglass bondo it up and sand it smooth.. I'll bet it will just crack in other places though. Im a bit surprised on how thin this piece of plastic was to start. I'm going the resin way for sure either way..
VonLuck is offline   Reply With Quote
Old 06-11-2011, 10:45 PM   #10
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Here is mine, it's on my 1976 26 footer
Phrunes is offline   Reply With Quote
22' 1975 Argosy rear door CMSmith All Argosy Trailers 6 11-16-2020 05:57 PM
Rear End Separation Permanent Fix? dmand001 Repairing/Replacing Floor &/or Frame 23 07-24-2017 02:12 PM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
Rear light housing seal--how? OB Bambi Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 04-09-2011 04:33 PM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
