Old 11-29-2017, 11:03 AM   #1
1976 Argosy 28
Terrell , North Carolina
Argosy rebuild order
I'm planning my rebuild and need some advice on the order I should go in. These are high level, I know there will be hundreds of smaller steps
1. Gut the interior
2. Remove all windows, vent, etc... to be refurbished
3. fix any shell issues
4. Remove shell and fix frame and replace the floor
5. re attach shell
6. Paint exterior
7. re attach refurbished windows, vents, etc
8. Interior
OR
1. Gut the interior
4. re attach refurbished windows, vents, etc
5. Remove shell and fix frame and replace the floor
6. re attach shell
7. Paint exterior
8. Interior
I'm not sure if I should refurbish windows and reinstall before painting or after. If I do it before, the shell behind the window frames won't have fresh paint and the caulking around the windows may mess up the look of the new paint (can the caulk be painted?). As I write this I'm thinking re attach windows after painting...anyway please let me know your thoughts from lessons learned.
dhbinkley is offline   Reply With Quote
Old 11-30-2017, 11:20 AM   #2
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
Gut the interior, remove the shell, fix the frame, do the floor, put the shell back on, then do the windows, doors, interior, paint in any order. Vulkem sealant can be painted. It will likely be easiest to do the windows when the interior is out after you have the shell reinstalled. Seal the inside of the shell with seam sealer.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 12-03-2017, 05:24 PM   #3
AlbertaBound's Avatar
1975 Argosy 28
1975 Argosy 22
1978 Argosy Minuet 6.0 Metre
Camrose , Alberta
I rebuilt windows before paint. Just make sure you use a paint-able caulking. They were installed and caulked before paint from factory. If you do not want painted windows then I would consider installing them after paint.
AlbertaBound is offline   Reply With Quote
'74 Argosy 20' Motorhome restoration/rebuild bkahler Argosy Motorhomes 1769 10-17-2020 11:04 AM
Martin's Argosy Rebuild Thread martin300662 Argosy Motorhomes 1113 06-19-2020 11:07 AM
Project Barley Hound 1975 Argosy 28' rebuild GoNomad All Argosy Trailers 10 03-29-2018 09:27 PM
1974 Argosy MH dash A/C rebuild bkahler Argosy Motorhomes 1 03-16-2013 04:47 PM
Argosy rebuild list bkahler Argosy Motorhomes 2 07-25-2008 01:21 PM
