Old 03-08-2018, 10:19 AM   #1
vintageracer's Avatar
1977 Argosy Minuet 6.0 Metre
Nashville , Tennessee
Aluminum Floor
This weekend I am going to look at June of 1977 production 20 foot Minuet that I have been told about. Reading the forum it "appears" given the model year and production date that this Minuet might have the aluminum floor and aluminum cabinets.
Can anyone tell me with any accuracy when the aluminum floor went into production, the possibility that this trailer is so equipped and the best way to confirm the floor with the complete belly pan intact?
I look forward to your responses!
Mike
Remember "Drive Fast, Turn Heads, Break Hearts"
vintageracer is offline   Reply With Quote
Old 03-08-2018, 02:38 PM   #2
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
Look into the area where the furnace is installed. You can usually find bare floor there.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 03-08-2018, 02:42 PM   #3
2007 22' International CCD
...or under the fridge looking in from the lower vent, if there is one...I can see bare floor under my water heater as well from inside the closet.
Old 03-09-2018, 08:03 PM   #4
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
The Minuet was in production from 1977 to 1979. Three models were made. A 6.0 , 6.7 and 7.3
To the best of my knowledge all years and models had aluminum cabinets. As far as the aluminum subfloor all 6.0ís had them, some 6.7ís and few if any 7.3ís.
If the original carpet is still there it does not go under the dinette seats or the lounge.
The subfloor is a foam sheet sandwiched between sheets of aluminum. The aluminum was painted white.
Also like mentioned in posts above the furnace is located under the oven. The refrigerator exterior access door should expose the floor.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 03-09-2018, 08:12 PM   #5
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
My 73 has aluminum cabinets.
1973Argosy is offline   Reply With Quote
Old 03-10-2018, 04:50 AM   #6
Thank you all for sharing your knowledge.
I will let you know what I find.
Mike
Aluminum corroded aluminum cole3444 Ribs, Skins & Rivets 8 04-09-2014 07:17 AM
Aluminum over aluminum wall covering? adwriter73 Upholstery, Blinds, Walls & Interior Finishes 7 07-03-2010 10:47 AM
'78 Minuet with Aluminum Floor overlander64 All Argosy Trailers 15 01-30-2009 01:42 AM
Is Aluminum Aluminum Ganglin Ribs, Skins & Rivets 6 06-26-2007 09:47 AM
old aluminum and new aluminum hill4th@gvtc Ribs, Skins & Rivets 6 08-03-2006 07:00 PM
