Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 02-08-2007, 08:54 PM   #21
gotair's Avatar
Send a message via MSN to gotair Send a message via Yahoo to gotair
your overhead fans work on battery power so if you have a dead battery your fans won't work... the heater will not work properly either... you would think that when plugged in they should but if battery is dead they don't...
Life's short...take your kid camping
gotair is offline   Reply With Quote
Old 02-09-2007, 04:16 AM   #22
MotorSeven's Avatar
Thorn Hill , Tennessee
Gotair, the battery is charged. I have to get out a test light& see if i have power, just been to busy with the other stuff.....
RD
MotorSeven is offline   Reply With Quote
Old 02-09-2007, 04:25 AM   #23
MotorSeven's Avatar
PIc's ..
a before and after of the yellow abs inner cap & Tambour....
Name:	'73 Argosy 20 004 (Small) (2).jpg
ID:	32041   Click image for larger version
Name:	'73 Argosy 20 002 (Small) (2).jpg
Name:	'73 Argosy 20 001 (Small).jpg
ID:	32043   Click image for larger version
Name:	'73 Argosy 20 005 (Small) (2).jpg
Old 02-16-2007, 07:02 AM   #24
MotorSeven's Avatar
fans...
I was getting power to both fans, so i removed them and hosed them down with electrical contact cleaner, then spun them by hand for a few min. They both run like new now. Even the micro switch in the stove vent works!
RD
Old 03-24-2007, 09:41 PM   #25
gotair's Avatar
thats what I did ... the bathroom fan was just alittle bit sticky from non use... I took the screen off the over head living area and tapped on it with the handle of the screw driver and what da ya know ...worked like a champ try silicone spray for other lube needs it works without attracting dirt and dust if you need to lube something check autoparts store for the good stuff....
Old 03-24-2007, 09:44 PM   #26
gotair's Avatar
in your befor and after picks one of the picks looks alittle like the exhaust vent to the fridge... was this also redone ? looks like they turned out real nice ...
Old 04-11-2007, 04:24 PM   #27
MotorSeven's Avatar
Update..
Sorry, i have been remiss in updating the pic's. But, the move from FL to TN was pretty hectic, and our arched steel building got delivered 2 days after we arrived, so work on that commenced at once. We are living in the Argy while i finish the apt inside the building. As soon as we get some of our "stufff" out of the Argy i will soot some pic's of the interior. I do plan on painting the exterior sometime this summer before we take off to Manitoba. The new door seal fixed the small leak that showed up on the floor. Then, a new leak developed over the stove top, running down the wall in several rivulets. I suspect that the lack of caulking on the stove vent is the source....probably blew off during the 900 mile trip to TN. We now have a 30x40 tarp covering most of the trailer and gives us some dry space out in front of the door. It's tacky as heck, but where we had to park to reach the septic tank put us in a field of E TN Mud! We have been it it over a month, and "knock on retro woodgrain", all systems are functioning correctly.
Here is a pic or two....
RD
Name:	Arches all up(small).jpg
ID:	35479   Click image for larger version
Name:	Arches going up (Small).jpg
Name:	Loaded and headed for Tenn (Small).jpg
Old 04-11-2007, 04:49 PM   #28
Old Paint, rolling again.
sfixx's Avatar
1973 Argosy 20
Lorain County , Ohio
Images: 12
What an adventure Great to hear from you and glad the move seems to have gone well. Your location is beautiful! Good luck with your "nesting".
Steve
Have you never questioned those who travel? Have you paid no regard to their accounts- Job 21:29
sfixx is offline   Reply With Quote
Argosy Motorhome Manual & Brochures WANTED Rik Argosy Motorhomes 40 02-13-2022 05:20 PM
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 8 05-11-2017 04:42 PM
I just bought a '76 28' Argosy MH!!!! Mr.Motorhome Argosy Motorhomes 3 05-17-2004 09:02 PM
New Argosy owner! barbwire All Argosy Trailers 33 04-15-2003 07:14 PM
