Old 04-10-2021, 05:57 AM   #1
1972 Argosy 24
Ann Arbor , Michigan
72 redo
Iím doing a complete over hall just started the frame and under belly 👍
1972 is offline   Reply With Quote
Old 04-10-2021, 09:50 AM   #2
Biggmixx's Avatar
1978 Argosy 30
Auburn , Washington
Welcome to your new adventure. Post lots of pictures.
Dave
Biggmixx is offline   Reply With Quote
Old 04-10-2021, 09:53 AM   #3
1966 22' Safari
Fredericksburg , Texas
Welcome and please post some pictures. I donít know much about an Argosy, but would love to follow along to learn. Good luck
Bubba L is offline   Reply With Quote
Old 04-10-2021, 11:06 AM   #4
Eric 26 Argo's Avatar
Airstream - Other
Knoxville , TN
Talking
Cool glad to hear. I think you will find uploading photos will be the hardest part.
Eric 26 Argo is offline   Reply With Quote
Old 04-10-2021, 02:26 PM   #5
Peter417's Avatar
1966 17' Caravel
1972 21' Globetrotter
SW , Missouri
A 72 what?
NWA MTB
Peter417 is online now   Reply With Quote
Old 04-13-2021, 11:42 AM   #6
1972 Argosy 24
72-argosy 24í and trying to post a photo
Old 04-13-2021, 11:49 AM   #7
1972 Argosy 24
Started with the under belly
The frame and wood look grate I custom made my replacement part
Old 04-13-2021, 12:00 PM   #8
aaryno's Avatar
1972 31' Sovereign
Tucson , AZ
I see the OP uploaded a photo. The rest of the reno is easy.
aaryno is online now   Reply With Quote
Old 04-13-2021, 12:01 PM   #9
aaryno's Avatar
1972 31' Sovereign
Tucson , AZ
Congrats! And Welcome!
Old 04-14-2021, 08:47 PM   #10
Biggmixx's Avatar
1978 Argosy 30
Auburn , Washington
I like your fabricated crossmember. With a welder you can make anything. Most of my crossmembers were so rusted I couldn't use them for patterns. You doing shell on or off...it looks like you've got your belly off and working from the bottom.
Dave
Old 04-15-2021, 04:38 AM   #11
1972 Argosy 24
Frame on
Starting with the bottom cleaning and painting the frame insulation then removing the interior skins to remove mouse crap , the camper is useable condition we camped 3 times . Iím not putting the tanks underneath trying to make a 4 season camper planing on camping in Michigan over Christmas weak to test it out 😃
Old 04-22-2021, 12:29 PM   #12
Airstream - Other
Knoxville , TN
Camping in Michigan over Christmas????? You know the point of the wheels is so you can take them with you Florida during the winter.
Old 05-01-2021, 08:38 AM   #13
Houston , Texas
This might be a silly question but what tool did you use to cut out the rear member? Also were you planning on replacing any of the rotted 2x4s?
Disable is offline   Reply With Quote
Old 05-02-2021, 03:51 AM   #14
1972 Argosy 24
I used a grinder and thin wheel or cut off wheel , the 2x4 s are bad only about 3Ē I will install a new one right beside the existing one , and add weld a new bracket to the new ibem or cross member and attach the outher end to the frame cross member about 5 feet long I will not have to replace the plywood or frame off just the vary back 6 inches of plywood I will try to post more next week
Old 05-02-2021, 04:57 PM   #15
1972 Argosy 24
72 redo
Trying to post a photo of frame rail that I replaced and then showing wire brushed the painted rust proofer on the frame itís going nicely
ID:	394716   Click image for larger version
Bathroom redo peggy welch Sinks, Showers & Toilets 7 02-14-2009 11:06 AM
Flexsteel seat redo GlenCoombe General Motorhome Topics 4 07-19-2005 09:10 AM
79 Excella Bathroom redo zamboni Cabinets, Counter Tops & Furnishings 0 03-25-2004 08:23 PM
'72 Agrosy - redo? edmatlock All Argosy Trailers 1 11-10-2003 06:43 PM
Instrumentation/Dashboard redo thenewkid64 Mechanics Corner - Engines, Transmission & More... 1 06-03-2002 09:02 AM
