Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 11-17-2017, 07:14 AM   #1
ajrose2's Avatar
1972 Argosy 22
1976 Argosy 28
Buxton , North Carolina
7 way trailer plug wire ‘72 Argosy
Ok guys this may have been asked before, and TG Twinkie has been helping me some messages.
I have attached a picture of how my trailer 1972 Argosy 20ft was wired to the 7 way plug... one thing I found wrong was the reverse lights were connected to positive (black) wire for the trailer plug that has since been changed. I will be added a connection/junction box... but I have a couple of wires from the trailer plug I don’t know what they would hook to on the trailer side... here’s what I know
Trailer plug into tv To Trailer side
Red Red left turn/stop
Brown Brown right turn/stop
Green Green running lights
Yellow Black reverse lights
Blue (big wire)
Black ???
White ????
I also have a white cable laying down on the ground it is marked in the picture as brake cable, cause that is what is labeled on the cable wire, it has a black and white wire with in it.
Also how can I hook up a new breakaway switch as well... I do not have a battery installed in the trailer... there are wire big wires near the converter and 12 volt fuse panel not hooked up.... black, white, red, and blue... I can post a picture of that later if needed...
any help is greatly appreciated, I am pretty handy, I have changed out starters and dropped a transmission to change a fly wheel before, but the wiring for this trailer plug might push me over the edge.
ajrose2 is offline   Reply With Quote
Old 11-17-2017, 08:45 AM   #2
ajrose2's Avatar
1972 Argosy 22
1976 Argosy 28
ID:	299305Click image for larger version
ID:	299306Click image for larger version
Here are pictures of my converter...
Old 11-17-2017, 10:10 AM   #3
1974 Argosy 26
Dana Point , California
This is most likely what they are:
Blue = trailer brakes
black = 12v power to trailer
white = ground
Check the position that each wire has to your tow vehicle. this will answer the questions for certian.
The cable labeled brakes has the wire that sends power to the brakes and the ground for the brakes. Most likely the white is the ground and the black is the hot to the brakes.
Here is the wiring for the new breakaway switch.
one wire needs to be hooked up to the 12V power post in your junction box and the other one needs to be hooked up to your brake power post in the junction box.
Peter Culp is offline   Reply With Quote
Old 11-17-2017, 10:22 AM   #4
Dingo Girl's Avatar
1967 17' Caravel
Oak Creek , Colorado
The blue one is your charge line. To charge trailer battery from TV.
Dingo Girl is offline   Reply With Quote
Old 11-17-2017, 10:25 AM   #5
Dingo Girl's Avatar
1967 17' Caravel
Old 11-19-2017, 08:13 AM   #6
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
You may also like
https://www.etrailer.com/faq-wiring.aspx
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Trailer-plug wire Color Code heslinhotel All Argosy Trailers 7 02-02-2014 12:35 PM
Inexpensive way to protect your 7-way plug SmokelessJoe Lights - Interior & Exterior 6 03-05-2011 02:08 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 05:24 PM
