RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 04-27-2009, 11:47 PM   #1
Y2k_Knight's Avatar
Barstow , California
Send a message via Skype™ to Y2k_Knight
What's it worth?
I'm looking at buying one of two 1975 Sovereign's. Both say "everything" works (be assured, before I actually put money out I will pay a reputable RV shop to inspect it).
One is for $8500 the other is $5000. What's a good/fair price?
I just found out on the $5000 unit the sunscreen coating which is inside the thermopane is deteriorated. The remedy is ignore it or replace all of the windows... I'm voting for option 2 but I haven't a clue how much windows are.
I would appreciate input from those with more knowledge and experience.
Just in case this falls through... I'm looking for a 70's Sovereign with vista windows over stacked windows, I'd prefer bedroom in the back but I can live with a bathroom there too.
Y2k_Knight is offline   Reply With Quote
Old 04-28-2009, 06:17 AM   #2
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Y2k,
Have you seen the Price VS Condition Guide? Take a look and maybe it will help you along. According to the guide both trailer prices you mention fall into the "Average" Condition column and one is at the low end of the scale and the other at the tippy top of the scale. So maybe the sellers have seen the page I linked . Good luck with your inspection and choice.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 04-28-2009, 06:30 AM   #3
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Most of the 70's AS with vista view windows have the double pane windows with the "stuff" sandwiched between. You can often break out the inner pane and clean and seal and leave just one pane in place. Sometimes you can take the inner pane off and replace it after cleaning, but it's tricky. The rear bedroom Sovereigns are prone to have frame sag at a higher rate than the mid-bath ones. Lots of weight in the rear with an inadequate frame for the rear bath. It can be fixed, but is expensive. $8,500.00 seems high unless a lot of restoration and updating has already been done. I'm sure I have much more than that invested in my 78 Argosy, but selling for what you have invested is not often possible. Axels can be a problem for older trailers, so read up about this expensive replacement too. Go take a look and if you really want it and know what you're getting into, go for it. We all over look the faults in a trailer we just have to have. As long as you're not facing major repair to get him on the road, these are great trailers to own. We have having fun with our 76 Sovereign without putting much money into it. Take a look at this side view and see how far up on the tires the trailer is riding. You should be able to see a good bit of the tire over the wheel if your axels are not completely shot. Good luck.
Judy At Home in Oklahoma
juel is offline   Reply With Quote
What's it worth?? niftypkg 1970 - 1973 Overlander 2 05-24-2007 10:39 PM
Is it worth it? marvin Trailer Values 7 02-10-2007 02:25 PM
For what it's worth.... Anon All Argosy Trailers 12 04-14-2005 11:06 AM
How much is it worth? RichardT Off Topic Forum 4 01-18-2005 09:35 PM
What's it worth? JNB 1974 - 1979 Sovereign 2 11-15-2004 11:59 AM
