RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 09-10-2013, 03:51 PM   #1
jlsherman's Avatar
1977 31' Sovereign
Indianapolis , Indiana
What is this?
It's on the street-side of the AS...towards the rear. It looks like a light, but what's it do? Thanks, Jason. 1977 31'
ID:	195397   Click image for larger version
jlsherman is offline   Reply With Quote
Old 09-10-2013, 04:01 PM   #2
FL Crackers's Avatar
2012 27' FB International
Waynesville , North Carolina
I believe it lights if your shore power's polarity is reversed. Probably and issue back in the day. I've not experienced it personally.
Mike & Laurel
Waynesville, NC
2012 27FB Int'l Serenity
2016 RAM 2500
FL Crackers is offline   Reply With Quote
Old 09-10-2013, 04:28 PM   #3
DKB_SATX's Avatar
Alamo Heights , Texas
FL Crackers is right, that's the polarity light. It is not a good thing, it provides a possible path to electrify the shell if a couple of things go wrong. Airstream stopped using them long ago, and I believe they recommended that the existing polarity lights be disconnected. I used the hole for the polarity light as an excuse to install a Marinco 30A inlet in my 28' trailer.
David
Zero Gravitas 2017 Flying Cloud 26U | WBCCI# 15566
Old 09-10-2013, 04:54 PM   #4
1977 Argosy 24
Milltown , Wisconsin
There is an electrical box inside, opposite the light. With the trailer unplugged, take the cover off of the box and remove the wire nuts from the wires that go to the light. Pull the wires apart and then with the wires disconnected from the light, cap the wires that used to go to the light with the wire nuts. Put the cover back on the box and enjoy your Airstream.
ventport is offline   Reply With Quote
Old 09-11-2013, 08:37 AM   #5
jlsherman's Avatar
1977 31' Sovereign
Thanks for all the help. Ill make sure it's disconnected.
