Are you talking city water or fresh water tank. For city water the original location should be in the rear roadside corner on the belly pan. You should at least see the old hole there. For fresh water tank fill there should be a cover roadside in front of the axles about 2 feet above the ground on the side of the trailer.
City water. They replace the floor so there is no hole.
Speaking of fresh water tank, I don't know how long it has been since the fresh water tank has been used. I know I will need to disinfect it. Are these tanks plastic or metal? If it is metal I guess I will have a whole new set of issues.
