RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 01-25-2010, 01:55 PM   #1
Port Richey , Florida
Towing Adapter for lights
Can someone tell me where i can get an adapter for a newer truck to hook up to a 74 model i am purchasing? Does anyone have a phtoto of one?
This is my first airstream, so any help is really appreciated, thanks.
FloridaMV is offline   Reply With Quote
Old 01-25-2010, 02:22 PM   #2
CaddyGrn's Avatar
1963 16' Bambi
1962 22' Safari
Yreka , California
If you do not own the Airsteam or have it in your possession yet... ask the current owner to take several digital photos and email it to you. Or at least call you and tell you what the hookup pattern is like.
We have a vintage dingy sailboat and we were able to find a universal adapter for it (1960 vintage) at our local auto store.
CaddyGrn is offline   Reply With Quote
Old 01-25-2010, 03:17 PM   #3
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
The current industry standard is a 7 pin round connector with 6 flat blades plus a center connector. If you have a modern tow vehicle you should have this on it.
Check with the owner of the Airstream and if it has this connector you are home free.
It may have a connector with all round pins as that is the way it would have been from the factory. Most of these have been changed out over the years to the industry standard.
If it has the round pin connector you will have to change it out to the new one. They are available anywhere.
To complicate it more until 82 Airstream did not use the now standard color code.
The new connector will have the connections labeled by COLOR
Here is a list The first color is the AS then the function and then the industry color
RED Left turn/stop RED
GREEN Tail/clearance Green
Brown RT/ stop Brown
BLUE charge line Black
White Ground White
Yellow Brake Blue
Black B.U. Lites Yellow
Italics are the ones that change colors
My thanks to Charlie Burke for providing this info many years ago
Hope it all make sense to you
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
1974, 31', sovereign, tow connector
New '69, 110 adapter too much for AC? stowaways General Repair Forum 2 06-26-2009 02:52 PM
'76 TV adapter Chip Arnold Audio, Video & TV 15 08-05-2008 08:23 AM
new shower adapter? kiltchick84 Sinks, Showers & Toilets 2 07-01-2008 03:39 PM
4 to 7 pin adapter ? Dan S Towing, Tow Vehicles & Hitches 24 03-10-2007 08:01 PM
Adapter Daisy2 Electrical - Systems, Generators, Batteries & Solar 7 03-24-2006 08:51 AM
