Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1974 - 1979 Sovereign
Old 07-11-2017, 12:15 PM   #1
1975 31' Sovereign
Prudenville , Michigan
This Thing-A-Majig
. How hard is it to get off and on? What is the best method and tools to do it?
Hamptastic75 is offline   Reply With Quote
Old 07-11-2017, 12:28 PM   #2
Reads a lot
Titusville , Florida
I am not sure what I am looking at.....
Lauri
She Believed She Could so She Did.
kendrick.l.j is offline   Reply With Quote
Old 07-11-2017, 01:53 PM   #3
1975 31' Sovereign
It it's a long metal strip that connects the ceiling to the walls. Closes the gap between the two. Looks like it's probably easy to get out. But I don't want to replace it. Just strip off the paint. It would be easier if I could take it down.
Old 07-11-2017, 03:05 PM   #4
1967 17' Caravel
I think one or the other panel has come out first. Then the piece in question will come free from the other panel. Sort of a "I" shape that engages the edges of each panel. I think.
David F is offline   Reply With Quote
Old 07-11-2017, 03:30 PM   #5
1972 25' Tradewind
McHenry County , Illinois
The center roof panel needs to be bent down slightly in the middle after removing the lights and a/c shroud. PIA.
The trim strip is a "J" channel. I think its riveted to the ribs.
Might be easier to mask off and paint.
If you want I'll check my manual.
Tom.
Tom Nugler is offline   Reply With Quote
Old 07-17-2017, 04:45 PM   #6
1975 31' Sovereign
Thank you. I won't be removing it. I will just be masking off and painting it.
Didn't know there was such a thing as 14.5" rims 59toaster Wheels, Hubs & Bearings 1 05-04-2009 09:23 PM
Does this thing need a gasket? Lexxy Waste Systems, Tanks & Totes 5 07-10-2003 12:41 PM
The REAL thing... canny_banjo_man General Repair Forum 4 06-17-2003 03:00 AM
Help me turn this Dometic thing on!! 74Sovereign Refrigerators 1 03-10-2003 09:59 AM
The Real Thing 4521red Our Community 5 01-05-2003 12:01 PM
