RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 06-13-2009, 06:22 PM   #1
1978 31' Sovereign
Montverde , Florida
Replace AC Drain...Any suggestions?
AC Drain is leaking between the AC drain pan and the bottom of the trailer. I was hoping that it was run loose so that it could be replaced without taking the trailer completely apart. I had planned on coupling the new line to the old line and pulling/pushing it through...Didn't work.
Am I going to have to pull the trailer apart to run a new line?
It is the original AC, can I plug the main drain and allow the water to flow out the 2 side drains until I can install a better solution? Did not want to cause another problem.
Since this is the original AC, should I just bite the bullet and install a new AC that doesn't need a drain?
Thanks for the advice.
la4photo is offline   Reply With Quote
Old 06-13-2009, 07:17 PM   #2
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
What kind of AC is it? I just went thru this last week with a Coleman in my Excella. I had a leak in 2 places but managed to get it stopped. My biggest problem was a cracked pan but down below the tube did not clear the hole and I had to put a nipple in it so the water completely exited the drain hole. The city water inlet was also leaking which allowed the water to drain to the front of the belly pan because it was high in the back. I had three leaks which was really frustrating, but fixed all three and now is dry as a bone.
Good luck,
Joe
AirHeadsRus is offline   Reply With Quote
Old 06-13-2009, 08:24 PM   #3
lynn's Avatar
You could try inserting a smaller tube inside existing tube.
lynn is offline   Reply With Quote
Want to Replace Carpet in 73 31ft suggestions? AustinAir Floor Finishes 3 12-09-2007 06:16 PM
Want to replace shower drain LTD30 Sinks, Showers & Toilets 0 06-08-2006 10:41 PM
Want to replace shower drain LTD30 Sinks, Showers & Toilets 0 06-05-2006 10:38 PM
replace water drain valve Anniedog Plumbing - Systems & Fixtures 4 05-03-2006 08:16 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 05:09 PM
