RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 09-22-2006, 02:40 AM   #1
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Redoing a 31' Sovereign
It’s not as bad as it looks; the shell & frame are great condition it is just the one corner, about 30" W X 48L
After following this forum for a few weeks and now doing this retrofit I believe the route of the water damage on all these AS’s is the 2” fiberglass insulation not drying out and rotting the steel when it has a leak.
I’m removing all of the insulation under the floor and any where else I find it, replacing it with the foil bubble R-14 material.
I was looking at the banana skins there in good shape except there is slight perforation at each outrigger frame at the sharpest turn.
I’m not replacing those skins or I’ll never be ready for Thanksgiving.
What I plan on doing is removing the rivets at the bottom edge of the banana skin where it meets the belly pan thereby not disturbing the trim molding and insert etc.
Take out all insulation do the por etc.
I’ll cut 4” x 6” patches and insert them inside the banana skin where the perforations are with some sealer and a few rivets.
There will be no insulation under the floor; I will seal the wood with fiberglass resin.
Inside the whole floor will get fiber glassed.
The whole floor inside will get the foil r-14 under the Pergo.
I’m never doing this job again, this should last forever.
Plenty of rot/rust right there, but when I look a little further the paint on the frame is shiny black. I’ll weld in some 1/8” steel to beef it up do the por 15 thing.
Put new belly skin in rear, about 60x60 area.
I think I can reuse the belly skin in the front.
When I bought this there were no rear beds, so I'm building a short queen cross ways with access from outside thru a luggage door.
I’m saving one of the overhead cabinets for bedding etc.
Bath will stay except new toilet shower head & controls.
All new pex plumbing, removed steel duct work replacing that with 4" flex insulated cost $11.
Besides weight savings it will allow more space under the kitchen & toilet sinks.
The kitchen will be rebuilt as it was same fronts all the tambor is good. A new stove top will replace the original, new Formica top.
The wardrobe doors and frame were removed the upper cabinets will stay; bunk beds will go in that space. I’m trying to to work a design where the upper becomes a seat back when not in use as a bed. Not sure it will layout, but will try a few idea’s
Fridge New and pantry are staying the credenza in front of the fridge will go.
As well as the table and Gaucho thinking about doing a wrap around dinette, or L shape arrangement???
The Univolt works but will go, a new 55amp power center is planned removing the original breaker box.
Name:	Tail lit leak result (Medium).jpg
ID:	26194   Click image for larger version
Name:	removed floor (Medium).jpg
Name:	Leak rot floor (Medium).jpg
'77 Sovereign Intl 31' CB
Old 09-22-2006, 02:48 AM   #2
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
All blocked up ready to get dirty
The damage
Name:	1_blocked up (Medium).jpg
ID:	26197   Click image for larger version
Name:	2_drop pan under rotten floor (Medium).jpg
Old 09-22-2006, 02:54 AM   #3
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
The pan had perforations in it, the stabilizer mounting plate is paper thin and the frame needs a bit of reinforcement
All this because of a leak in the tail lite that was fixed with silicone by PO
Name:	3_rot 2 (Medium).jpg
ID:	26199   Click image for larger version
Name:	4_Pan under 3 (Medium).jpg
Old 09-22-2006, 03:00 AM   #4
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
The galley is out, all the steel ducts are gone. After this was taken all the copper was also cut out waiting for PEX.
Name:	galley (Medium).jpg
Old 09-30-2006, 10:10 AM   #5
1971 31' Sovereign
Springfield , Missouri
The fiber gear on top that raises the tv antenna has teeth broken off of my '70 31" Sovereign. Any clue where to get a new part or assemblyu?
Gary
Gary Summers is offline   Reply With Quote
Old 11-29-2006, 08:17 AM   #6
1973 23' Safari
Maryville , Tennessee
Images: 13
Have you made any progress on the bunks? Any pics?
kneal is offline   Reply With Quote
Old 11-29-2006, 08:23 AM   #7
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Here's a thread on the rear queen bed frame.
the bunk beds are going to be later, after the sofa.
Old 12-27-2006, 08:39 AM   #8
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
New Galley Photos
IT IS FINISHED!!!
Okay, not to hijack here but I FINALLY installed my galley after over a year of it sitting in the LR. I installed a new countertop, Suburban NT-30, a new water pump, all new water lines to freshwater tank, Intellipower converter, new PF faucet, and a new Suburban oven/stovetop.
Kneal, I will commence bunk building this week. (I have already drawn up design and will hopefully start cutting wood tonight.) My emphasis is strength with as little weight as possible.
I'll post pics as they occur.
Oh yeah, the subject in the photos is a '72 Sovereign CB.
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 12-27-2006, 08:44 AM   #9
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
yeah! Looking great... I really like the ocuntertop and new stove. My old harvest gold one is in very good shape, so I am procrastinating replacing it, but a modern look does help. Did you laminate the top yourself or buy it and do the cuts? Around here it seems hard to find the laminate not already glued.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 12-27-2006, 11:35 AM   #10
Zeppelinium's Avatar
1973 23' Safari
1977 23' Safari
2014 25' Flying Cloud
Palmer Lake , Colorado
Gary
maybe the one on this Amabassador will turn out to be OK
http://www.airforums.com/forum...ght=dead+baker
Zep
Zep@Charmedquark.net
Old 12-27-2006, 12:00 PM   #11
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Nice job Ron,
The kitchen counter looks great.
Is the backsplash glued on?
Keep us posted on the bunks. I'm leaning that way as well....
-Tim
theVAP - Airstream Podcast
Old 12-27-2006, 03:57 PM   #12
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Looks great, Nice job!
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 12-27-2006, 08:53 PM   #13
PizzaChop's Avatar
1973 31' Sovereign
Images: 202
Tim,
I had this countertop laminated professionally. (I cut out the plywood and took it to them. They achieved the rounded backsplash that I never could.)
I did the one in my Overlander myself (every step) and it turned out pretty good but the rounded backsplash is primo.
Alan, it's not that difficult but it does take time. There's a lot of removal (oven, sink, trim, etc.) involved though. (That's why it's great to start with a junker...makes it so much easier to tear it apart to get what you want! )
Ron Kaes
Psalm 112
www.paparonnis.com
Old 12-28-2006, 09:43 AM   #14
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I hear ya on that. I ordered my kitchen countertops from Home Depot, I measured the old ones, drew it out, they made em, and I installed. Cost a lot less than I expected, and I got the sim granite look ready to go. Cutting out the sink hole was the only tricky part. I could do the same with the trailer, but that is a little ways down on the project list...
AIR #005
retired!
'85 Sovereign 25' j54mark 1984 - 1989 Sovereign 13 11-07-2013 12:24 PM
'78 Sovereign Awning Joan D'Andrea Awnings 6 01-03-2006 08:34 AM
dull roof on 1986 31' sovereign Daryl Miron Roof 12 07-25-2005 01:37 AM
Kichen remodel - 85 Sovereign 25' j54mark Cabinets, Counter Tops & Furnishings 6 10-14-2003 07:20 AM
Help with Ancient Sovereign patti 1955 - 1959 Sovereign 2 06-06-2002 03:23 PM
