RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 01-28-2011, 02:34 PM   #1
Viper2's Avatar
Jay , Maine
Talking REDO, REPLACE, '74 Sovereign
I just started to gut my 74 soverign. Big time rotted floors and some other minor issues. I so far have stripped 80% of interior and working on removing the bathroom and twin beds in rear.
Frame is in great shape in the front and I will POR-15 that. I am storing the parts all over since I dont have much room and am doing this renovation outside in glorias maine winter weather. LOL
As soon as the inside is gutted, I will drop the belly pan to get at things and then install the new floor. Before that happens, Im trying to find a place inside to recaulk all the vents,windows and seams.
If I could figure how to add photos to the post Id show the work.
Viper2 is offline   Reply With Quote
Old 01-28-2011, 03:01 PM   #2
Kevin245's Avatar
Sounds like you have your work cutout for you.
Here's a post with photo attachment information.
Forums 101 - posting, accounts, basics - Airstream Forums
William C. Swinney
Old 01-28-2011, 03:27 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Make sure you put everything in bags with very descriptive labels. 6 months from now, you may not remember which screws with to which hinge. Take a lot of pics and measurements of exactly where things are. Taking a little time on the tear down and making lots of pics will save you a lot of time during the install.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 01-28-2011, 06:01 PM   #4
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Or, just throw that stuff away. I for one think that the original interiors are u.g.l.y.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 01-28-2011, 06:06 PM   #5
Ottawa , ON
Or keep it for templates; wall curves, heights, hardware, etc.
Not so easy to re-create those sizes if/when you want to replace or upgrade them.
Old 01-28-2011, 09:38 PM   #6
Viper2's Avatar
Jay , Maine
thank you
thank you very much, I appreciate the fast reply
Old 01-28-2011, 09:47 PM   #7
Viper2's Avatar
Jay , Maine
Not a problem, I have been bagging my butt off and marked walls and overlaps and every thing and all ready have 2000 photos to back up my memory. lol
Know if I can just post some. Im working on it
THANKS
Old 01-28-2011, 09:49 PM   #8
Viper2's Avatar
Jay , Maine
Yes. Im saving all the wall trim and cabinets as templates to make new and of a lighter color. Just part of the restore then I will attend a AS event or offer them up to those who need it when im through
Old 05-30-2011, 05:21 PM   #9
Ottawa , ON
Viper2,
How are you making out so far?
Old 06-02-2011, 06:37 AM   #10
Viper2's Avatar
Jay , Maine
Thumbs up Where am I at
Ok folks it has been a long cold winter and I didnt get as much done as hoped and know its summer and I am back to working on the AS when it isnt pouring out. So far todate I was trying to replace the floor by only removing the lower inside skin. Well, that approach worked for the first 3 sheets then I found major mice mazes (pathways) under the skin.
Sooooo, I decided to gut the whole trailer and was amazed of the damage these little guys did.
Since the last post, Ive removed everything from trailer but the 3 door closet, Removed all the insulation in the walls, Reworked the wire harness and main AC power coming in, patched some leaks, I got the new bath room window in ( got broken from vandals) before I got the trailer.
I will try to get some photos in here, if I can recall how, LOLOL
More to come, later
Keith
Old 06-02-2011, 07:13 AM   #11
Viper2's Avatar
Jay , Maine
Reminder
Viper2,
Aage, thank you for asking and reminding me of the post. I will try to update it with info and photos.
Keith
Old 10-01-2011, 09:44 PM   #12
reinergirl's Avatar
Hollis , New Hampshire
Calling Viper 2! where'd you disappear to???
reinergirl is offline   Reply With Quote
Old 10-14-2011, 03:13 PM   #13
Viper2's Avatar
Jay , Maine
Refurbishing 1974 soverign, part 2
OK many have asked where I am at and I havent been on much, so here are the details and I will send some photos shortly soon as I figure it out.
  • Removed and replaced entire floor with shell on.
  • POR-15 Entire frame and riggers.
  • Replaced 4 ft of rear main frame that was rotted(str side).
  • Replaced 3 rear cross members, with new modified box frame members.
  • Replaced 4 street side out riggers(rear).
  • Replaced 3 curb side out riggers(rear).
  • Installed new 110V AC wiring, removed old 2 circuit breaker from rear of trailer and installed a Furrion 30A Inlet and a Progressive Dynamics 4045 converter distribution Panel to handle AC/DC.
  • Replaced R-11 Belly Insulation and added an additional layer of Owens R-10 Closed cell Poly Board, giving me R-21 value. All foam board was sealed with Alum tape to frame.
  • Replaced new Belly pan entire length to include all side wraps over out riggers.
  • Replaced bath room window new. old one was broken into and wasnt ever found.
  • Removed Old TV antenna and sealed hole ( may replace at a later time).
  • Removed all windows and compartment doors and replaced gaskets, locks, shined the ALUM.
  • Found and fixed all leaks in shell (4 roof,2 ext lights,wheel wells and Rub rails).
  • Installed new 10 Gal atwood water Heater w/bypass valves for winterizing.
  • Installed new 42 Gal water tank.
  • Rebuilt Battery compartment and Door. New battery also. Later will be adding solar panels and more batteries.
  • Rebuilt Thetford Waste valves,40y old gaskets not good.
  • Had new thicker alum Black Tank pan built, grey tank was OK, replaced both pan's Insulation and heat registers.
  • Replaced all Exterior clearance lights, replaced round tail light canisters (4 total).
  • Replaced 1/2" copper Water line with PEX.
  • Replaced 3 ceiling vents with Fan-tastic vents.
Well folks I think that is it. Once im done with belly pan, I will rebuild main and branch propane lines, hook new regulator and tanks up. Then order the two new axles,tires and rims. Then its on to building the interior
Old 10-14-2011, 03:15 PM   #14
Viper2's Avatar
Jay , Maine
Whats new she asked. lololol
Hows your trailer renovation going?
Old 10-14-2011, 04:04 PM   #15
Ottawa , ON
Wow, that is one heck of a list, Viper2!
Can't wait to see the photos. Have a look at this thread, post #7 to see how to do the photos.
Old 11-14-2011, 07:32 PM   #16
reinergirl's Avatar
Its sitting in the parking lot at Colin Hyde's waiting in line to have its axles/frame and floor done! You've done so MUCH! I'm jealous!
But ya know the proof is in the pictures LOL
1974, sovereign
1969 Sovereign :: 1969 Airstream Sovereign evers310 Airstream Registry Discussions 0 08-19-2011 09:31 AM
'76 Sovereign Floor Replacement-2 gronlampa Repairing/Replacing Floor &/or Frame 0 07-24-2011 09:58 PM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 07:20 AM
