Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1974 - 1979 Sovereign
Old 10-05-2006, 04:44 PM   #1
1975 31' Sovereign
Gainesville , Florida
Jacking point for flat tire 31' Sovereign
I would think that the main frame-two rectangular beams running the length of the trailer-would be the best place to find a point to place a jack for changing a flat tire. By placing my heavy-duty hydraulic jack in a number of sensible locations,each time I attemped a lift I watched(and heard)the main frame start to fatigue. Please help,
rozwd.
rozwd is offline   Reply With Quote
Old 10-05-2006, 05:02 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
rozwd.
Get some 2x6 and run the non flat wheel up on it then you can change the other one. I jack mine just behind or just ahead of the axles.
Aaron
WBCCI #XXXX AIR #2495
Old 10-05-2006, 05:54 PM   #3
_
search the term jacking or 'jack points' and many threads on the topic will appear...
here is a pic johnhd posted showing how a ramp is used for lifting as wahoonc suggests...
and to change one tire of a double or triple...
http://www.airforums.com/forum...5&d=1128361020
and here is a photo from tinsel loaf, showing the best jack points...
http://www.airforums.com/forums/178629-post1.html
i questioned this since it is contrary to the owners manual...
last week when the factory raised my triple to lube the bearing...
this is EXACTLY where they placed the jack stands...
and where i will forevermore expect to place a jack...
cheers
2air'
Old 10-05-2006, 09:15 PM   #4
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Hi, Rozwd,
I carry a couple of ramps from Auto Zone that I bought for less than $50 to handle tire changes. On a recent trip, I used them twice.
When the tow vehicle is attached, a ramp is much faster and easier to use than a jack, although a hard surface is prefferred for using them. (Once I changed a tire on the side of US 1 on the grass and it worked okay, but I worried about it.)
My ramps were made by "Rhino" and are rated at 12,000 lbs. They don't become disfigured at all with the weight of a single wheel on them. (If you'll look in my gallery, you'll see a picture of my Excella up on one.)
Jacking on the frame rails between the axles, in my opinion, puts more stress on a localized point on the frame than using ramps, and, at least, in my 70's model, the frame is not very thick there. The axle itself spreads the lifting stress around more than a bottle jack will.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 04-06-2013, 09:36 PM   #5
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Been thinking - I have a lightweight #4,000 aluminum floor jack. Why not throw it in the back of the TV and put it under the axle bracket, if frames are so light. Better (more stable) than a bottle jack. Bad place to twink a frame!
Silver Hawk is offline   Reply With Quote
Old 04-07-2013, 03:28 AM   #6
on't need a jack to change a tire on a tandem or tri-axle Airstream trailer.
All you need is a couple of 2 x 6's.
Pull the good tire on the side that has the flat, up on it, and then change the flat tire.
Or, if you insist on using a jack, place it between the 2 tires and lift frame the axle mounting plate, but NEVER EVER from the axle tube.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 04-07-2013, 06:53 AM   #7
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I find the Lynx Levelers are useful for side to side leveling of the trailer, use under stabilizer jacks, and above all, for removing wheels. Safe and easy, and they store well and are easy to keep clean and tidy. I carry two sets of ten each.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Wingeezer is offline   Reply With Quote
Airstream Tire Failure Poll Phoenix Tires 150 05-14-2018 07:34 PM
235/75R15XL vs 225/75-15 trailer tire perryg114 Tires 129 07-18-2012 01:59 PM
Need spare tire rim for size 700-15 1976 has alum mag wheels Caravanner76 Wheels, Hubs & Bearings 3 10-18-2011 09:21 PM
1969 Sovereign :: 1969 Airstream Sovereign evers310 Airstream Registry Discussions 0 08-19-2011 08:31 AM
Wheel and tire Combo Mr & Mrs S Wheels, Hubs & Bearings 2 05-09-2011 10:10 PM
