04-04-2009, 06:28 AM
1977 31' Sovereign
Manchester
, New Hampshire
Good light weight Subfloor for bath?
I have cut out a piece of the bath floor behind the toilet and under inside skin had got water in and rotted it out . Ok here is the thing I DO NOT want to replace whole floor so I need a good light weight sub floor any suggestions?
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
04-04-2009, 07:11 AM
St. Cloud
I'd go with what was originally there. Does it seem like you're seeing 1/2"? Marine ply aims to minimize unrepaired veneer defects in middle layers. I had trouble getting that locally and used 19/32" underlayment ply on my Argosy -- that caused a mismatch with existing floor but wasn't too bad.
It's hard to visualize how minimal you can keep this repair. Pictures are gooder...
04-04-2009, 12:55 PM
1977 31' Sovereign
Manchester
, New Hampshire
Well I have the pictures on my cell phone.But I want to go over the floor not replace the floor it is only like a 1.5 foot by 2.5 foot piece I have removed and it is half over a beam and no support under the inside skin. So If i can over what floor I have now which is in good shape I would prefer that (how about aluminum ,or thin metal of some kind?)
Actually I am going over today Ill get some more pictures...
K/N Cool intake air
Duel power exhaust
04-04-2009, 12:56 PM
1977 31' Sovereign
Manchester
, New Hampshire
Also there is no weight to bare wherer the hole is ..
K/N Cool intake air
Duel power exhaust
04-04-2009, 01:22 PM
1972 Travelux Princess 25
Cobourg
, Ontario
Here is a good way. Get some plywood the same thickness as the old stuff. Cut out a nice neat patch. Lay the patch on the floor and cut the old floor to match. Use a router to rout a step in the floor and in the patch so they overlap. Put the patch in with wood glue and screws for a permanent repair.
This is too obvious but you have to measure back from the traced outline, before you cut, to leave enough material to overlap.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
04-06-2009, 08:47 PM
1977 31' Sovereign
Manchester
, New Hampshire
Fiber glass?
What about fabricating a fiberglass wood patch have the fiberglass over lap the wood subfloor have a tight fit with fiber glass over hang for support? anyone?
K/N Cool intake air
Duel power exhaust
04-06-2009, 08:52 PM
1977 31' Sovereign
Manchester
, New Hampshire
Front part of trailer subfloor.
The direct front part of the the floor where the two battery boxes and the Univolt is. It is getting week but I dont want to pull up the floor. What about fabricating a fiber glass subfloor over existing floor have aount 1/2 inch fiberglass subfloor and I could togle bolt floor down and deck screem it to . Would this be more problomatic or even work?
K/N Cool intake air
Duel power exhaust
04-12-2009, 10:28 AM
1977 31' Sovereign
Manchester
, New Hampshire
Actually the hole runs close to the rib beams I could put a piece of treated 2x4 across the length bolt it to the frame make a plywood patch matching floor and patch then screw patch to 2x4 then bondo or fill in seams and sand it . As far as the front goes could make a plywood patch with treated plywood and cut past first cross beam about a foot make a under liner for support and bridge patch to existing plywood then bolt it to the cross beam with new bolts and holes then bondo any spaces. I mean honestly I have another 15 years at least I can get out of this trailer after that I could do a full renovation.
K/N Cool intake air
Duel power exhaust
