RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 04-06-2003, 05:32 PM   #1
bwj1450's Avatar
Send a message via AIM to bwj1450
Battery Use
I have a question if someone could help me. I am new to airstream and have bought my first 1978 31' Sov. The battery seems new and I have it on charge right now. My question is what function does the battery serve to the trailer.
BWJ
bwj1450 is offline   Reply With Quote
Old 04-06-2003, 05:55 PM   #2
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Cool Just about everything!
The Airstream has dual electrical systems, 12 VDC and 120 VAC. On my '72 all of the lights are 12V. All of the venilation fans are 12V. The furnace blower is 12V, as well as the on board water pump. My 'fridge was replaced by previous owners, and is a 120 VAC model. You may have a propane/12 VDC /120 VAC model, or some variation. My TV and microwave oven are 120 VAC only.
The battery is used to power the 12 volt side of things when you are not connected to "shore power" as we like to call it, when you are in transit, or if you are camping at a site without 120 VAC power.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 04-06-2003, 07:42 PM   #3
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
The newer trailers even require battery power to operate gas appliances like the water heater and the refrigerator (control boards). I'm not sure if they reached that point in 1978 but be aware.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-06-2003, 08:33 PM   #4
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
bwj
another thing it does is to provide emergency power to your brakes, in the event your trailer were to detach from your tow vehicle via the breakaway switch.
also, it filters the output of the univolt that powers your trailer when "plugged in".
john
vintage airstream battery wildcat455 Electrical - Systems, Generators, Batteries & Solar 4 07-02-2003 01:50 PM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 09:43 AM
Installing battery problem flyfisher Electrical - Systems, Generators, Batteries & Solar 2 04-01-2003 06:59 PM
Univolt with Battery Minder COArgosy78 Electrical - Systems, Generators, Batteries & Solar 32 03-10-2003 08:59 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 03:58 PM
