RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-13-2016, 06:47 AM   #1
1975 31' Sovereign
orlando , Florida
Battery question
Do I have to have a battery if I'm wired up permanently to power? Thanks for the help
Ofdtruckie is offline   Reply With Quote
Old 11-13-2016, 07:28 AM   #2
1975 31' Sovereign
orlando , Florida
Oh it's a 75 sovereign
Old 11-13-2016, 08:11 AM   #3
Naples , Florida
If you have the original Univolt converter.......YES! That device requires the battery to act as a voltage 'filter' for the high VDC output of the Univolt.
If you replace it with a modern 'switch mode' type converter like a Parallax , they will operate without a battery in the circuit and provide a continual 13.6 VDC for your trailer's DC circuits.
IF you ever take the trailer on the road, you WILL be required to have a battery that is capable of operating the trailer brakes in the event of a disengagement from your tow vehicle.
lewster
Old 11-14-2016, 12:00 PM   #4
1975 31' Sovereign
orlando , Florida
Thank you very much that helps a lot.the univolt was changed with a newer one.
Battery Hold-down Strap Shorting Against Positive Battery Post rel Sprinter and B-van Forum 3 08-13-2013 11:32 PM
Question about wiring new battery charger on the battery side of the latching relay. BTUs4You General Repair Forum 3 07-27-2012 01:36 PM
To battery or not to battery 29348 Batteries, Univolts, Converters & Inverters 4 07-16-2006 03:02 PM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 01:04 AM
Battery check--why don't I ever have to add battery water? Kistler Batteries, Univolts, Converters & Inverters 8 05-17-2004 10:03 PM
