03-08-2020, 10:25 AM
#101
1977 23' Safari
Niagara on the Lake
, Ontario
The water heater bypass allows you to isolate the water heater when you winterize so you don’t have to fill t with antifreeze.
I’ve never felt the need to fill my tank from the city water inlet. The few times I’ve left a full hookup site and needed to leave with s full water tank I was unhooking anyway so I just filled up with water then.
I do t think there is anyway to keep water from freezing, so if you add an outside shower, just put valves inside to isolate it during cold weather.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
03-08-2020, 09:06 PM
#102
1986 34' Limited
1975 27' Overlander
Conifer
My friend wanted a dirty dog and foot sprayer in his trailer. They boondock a lot so a city water sprayer wasn't ideal for them. We plumbed one in the curbside cargo compartment. He can open the door, hook up his hose, and spray away with his 12v pump and fresh water tank as the supply.
I accused him of just wanting to squirt his wife while she was napping under the awning.
David
WBCCI #8607
VAC Region 11
See my 1966 Trade Wind Renovation Documentation:
Knowledge Base Airstream Trailers
See my 1975 Overlander Improvement Journal:
See our 1976 Sovereign Renovation Project:
03-09-2020, 08:31 AM
#103
1972 29' Ambassador
Boynton Beach
Originally Posted by andymeyer
We are STRUGGLING to get a gloss finish on our cabinets and benches and beds. I am not sure if I could paint an asphalt driveway black at times.
What kind of finish are you using? I used Pettit Paint Z-Spar Captain's Varnish 1015 to get a great finish. It takes about 4 coats, wet sanding with 220 in between coats to 320 before the last coat. The foam brushes from Amazon seem to work better than the Home Depot ones, could be my imagination. Be sure to never use the product from the can, pour it into a square hand-held paint pail. Keep a wet edge, and don't go back over previously painted sections (unless there's a drip). If you can, paint everything on the flat, but don't lay on excessive amounts, as it dries (eventually) with a wobbly finish.
09-06-2020, 06:10 PM
#104
1978 31' Sovereign
Lincoln University
, Pennsylvania
Making Progress!
We've been hard at work... Association told us we can't keep the trailer here after the 15th of Sept. so we have been working hard.
Center part of the ceiling is in - a bunch of 3W LED lights, the same panels as our flooring, and some aluminum trim. Still planning to add some colored LED's as an accent light. Got rid of the ugly air conditioner panel - had a couple of cracks, but was just plain UGLY!. Tucked the switch box up as tight as I could and 3D printed some vents (inlet vent is in the works right now - printing the brackets - louver is done.) The new outlet vent actually sends air to both ends of the trailer and seems to flow a LOT more air than the stock vent. My bride just wants a little louver added to blow some cool air down in the kitchen area.
The StreetSide bed and cabinets are all in. Mostly built from 1x2 and 1x3 poplar - reasonably light and strong. Now to get my little girls mattress made - we are trying to determine the best foams for a mattress unless someone's got some good suggestions. We were planning on 4" of extra firm and 2" of medium firm foam so she can flip which side she likes. Have a switch in to select AC or Microwave - not sure if we'll need this, but we have the option. Still need to run the USB cables for the tank and electrical monitors, but that's not a big deal.
The electrical stuff is all tucked in under the front bench. Inverter isn't connected yet, but everything else is. Plan is to have the inverter selectable - if it's off, 120 shore power powers everything. If the inverter is turned on, all house power goes through the inverter (just the outlets - bathroom, kitchen and utility. Fridge, micro, AC, and the streetside outlet by the microwave remain on shore power, along with the converter. If there's no shore power, then the only things powered by the inverter are available. Have wires for solar if we decide to add. Have room for 3 large house batteries - maybe squeeze four if so desired. Right now we've got 1 and it seems to run lights, etc... for 2 - 3 days of working out there.
I put the original doorbell back in - had to keep that - sounds too cool.
Bathroom is coming together. Using a linoleum product for the shower walls - shiny white. The floor is the blue glass tile that my bride put in. She's an awesome tiler. Working on getting counters for everything built... Plan is Cambria Quartz - white or black - any thoughts here? Need to order a new toilet - thoughts on this - what's the ideal these days?
Kitchen! Finally! it looks like a kitchen. We can't decide on the RecPro 20" or the Furrion 17" range - any suggestions on which? Someone says that the Furrion can't go less than 350F. Can't make my brides Bacon - cooked for four - six hours at 220F with some magic dust - delicious stuff! Stainless sink.
Drawers and doors - gonna buy them from one of these online shops who knock these things out fast - any suggestions? Simple shaker style doors.
Painting - Ughhh... We are biting the bullet and having someone who can paint, paint. We are getting quotes on this - hopefully not to painful since we can drop almost everything off - if not just leave the trailer with them.
09-06-2020, 08:16 PM
#105
1986 34' Limited
1975 27' Overlander
Conifer
Nothing like a deadline to keep things moving. Your trailer is really coming along.
You need to go buy a farm with say 400 acres around you so you can have your trailer on your ground without "rules and rules". I know such things are good for "community living" and keep guys like me from leaving an old truck in the yard for a few years, or maybe a couple of goats and some chickens, or some crazy modern art statue.
Keep us posted on progress.
David
WBCCI #8607
VAC Region 11
09-07-2020, 09:44 AM
#106
1972 29' Ambassador
Boynton Beach
I'd be careful about those LEDs, especially over the setees. Point lights like that can shine uncomfortably when seated. I wound up re-thinking mine when it turned out that they were too bright. I left the ones over the galley work surfaces, and they worked well to illuminate just the surface for the cook, and not turn the entire trailer into an operating room.
Maybe little difusers mounted over the lights?
09-07-2020, 08:20 PM
#107
1978 31' Sovereign
Lincoln University
, Pennsylvania
Lights...
Good point on the bright lights - didn't think about that part of it - they do have a ~2" diffuser on them already, but more could prove better. We did get them as 2700k lights and they are all dimmable. In addition, I'm going to have some other strip LED lights that shine sideways from under the center ceiling section, but these will be very low light - more for ambiance.
Anyone have thoughts on the Furrion vs the RecPro ranges?
09-25-2020, 09:02 PM
#108
1978 31' Sovereign
Lincoln University
, Pennsylvania
So, the 15th came. We took the trailer to our storage spot. But, it's coming back as we need to work on it. Cabinets, drawers, and the shower paneling are next - maybe tomorrow. Anyone have good suggestions on someone who can knock out drawers to size for reasonable and quality work?
www.strutairstream.com
09-26-2020, 10:00 AM
#109
1972 31' Sovereign
Lexington
Woodcraft makes prefinished birch drawer sides and bottoms. You would have to put together. We've always gotten good quality things from them, and they have a good reputation.
Kay
12-17-2020, 11:51 AM
#110
1978 31' Sovereign
New Smyrna Beach
How is your project coming? Haven't heard from you in a while.
