11-21-2012, 09:56 AM
#61
1978 31' Sovereign
Parkersburg
, West Virginia
Update: I have rear sag on the curbside only that needs fixed. The sag is caused by damage on the bottom of the frame between the axles. Here are some photos:
It's causing about 1/2 inch drop on the curbside tail end:
My plan is to remove the wheels and jack the frame to level. Then hammer out the bend and weld/bolt a plate to the outside of the frame rail. Any objections or suggestions?
02-28-2013, 11:51 PM
#63
1973 Argosy 24
Houston
Heck, just my 2 cents... you have the frame apart, I'd get some steel and have it welded in there after you straightened the frame out. If you used POR15 beware of the fumes. I understand they are toxic when welding.
Anyhow, I wouldn't pay $400 for a pair of steel plates.
04-04-2013, 09:19 AM
#64
1978 31' Sovereign
Parkersburg
, West Virginia
Its been awhile since my last post, things have been crazy. Progress has completely stopped up until this week due to weather conditions. My job is relocating me to Columbus, OH in May so this project has been kicked into overdrive. (At least getting the shell back on the frame so i can move the camper)
The frame has been welded and painted. Probably not as well as I would have liked, but desperate times call for desperate measures.
I'm buying the subfloor this week as well as the epoxy (West Marine?). Any suggestions on type of plywood/epoxy to use are welcomed and appreciated.
Also, any recommendations on where to by the aluminum channeling would be awesome. I've looked at Out-of-Doors Mart and they have a possible 6 week delivery time which if i can circumvent, would be nice.
I look forward to posting more frequently and I will include photos detailing the steps over the next few weeks.
04-06-2013, 08:41 PM
#65
Tool Hoarder
West
I used 3/4 " marine grade plywood. I bought a metal brake and bent up my own channel
05-31-2013, 06:33 PM
#66
1978 31' Sovereign
Parkersburg
, West Virginia
I really should be posting more frequently between steps. The may move date was pushed back due to issues at the new house. Tomorrow is the big day to put the shell on. In fact, I'll basically be going from a frame to a shell on situation from morning til night tomorrow. I've been trying to get as far along as I can but there are lots of areas where an extra set of hands really makes a difference. Here's the update from last post; Read on if you want to see what happens when you are under a ridiculously short deadline:
1. Purchased 1/2" ply for the floor (the size that was previously used) and cut all the floor pieces using the old floor as a template.
2. Drove to Airstream and bought channeling and two end bows.
3. Got Home and realized the new channeling was too big for the 1/2" ply and had to move up to 5/8". (so i now have an entire floor in 1/2" hanging out in my basement  )
4. Also, under a lack of judgement, the front and rear floor pieces that have the bow were cut under the assumption that the bow channel from airstream would fit. They do not.
5. Ordered West Marine epoxy and coated the flooring. Worst part of the entire process for me.
6. Cut the new channeling to size using old channeling as template.
I believe I have all of the necessary components to get the shell back on. Currently, they are all in pieces. I have two good friends that are coming over tomorrow and they are both incredibly skilled fabricators. Here's whats on the agenda:
1. Attach the flooring to the frame.
2. Attach the channeling to the floor/frame.
3. Lift shell from the ground using gantry cranes.
4. Place frame under the shell and jack until completely level.
5. Slowly lower shell onto channeling/floor/frame and pray that my measurements are correct and we can 'massage' the shell into the channeling.
Seeking Advice: I've seen countless posts and even youtube videos of shells coming off. I've yet to find a really good video/post about a shell going on (where gantry cranes were used; and by good i mean details about how you lined up the frame, etc.). I'm assuming its because most people give up after the shell comes off?
If anyone has any pics or good strategies to share about lining up the shell and frame when overhead lifting with cranes, please share. (i.e. what method did you use to counterbalance the weight of the awning so that the shell raises and lowers level?)
I am vowing here and now to get crazy with the photo documentation of the shell on process to maybe help shed some light.
One last question: If anyone has used the bow channeling that you get from Airstream, what did you do to get it to fit? I've read that you need to cut a section from the middle and weld it together. I do not have the equipment to weld aluminum so I'm considering just making the bow channeling a two piece situation on the front and back and sealing up the seam. thoughts?
05-31-2013, 07:48 PM
#67
Tool Hoarder
West
Dude take lots of pictures!! Also make sure that the length of the sub floor is correct or you will run into problems. Mine was a tad too long and damaged the rear corners so bad I had to replace both outer skins.
06-02-2013, 10:20 AM
#68
1978 31' Sovereign
Parkersburg
, West Virginia
At Last!
The Shell is back on the frame/floor!!
Here's what I started with this morning:
Here is what we ended up with:
NOTE: Damage on the quarter panel is from the PO.
Details in the following post.
06-02-2013, 10:31 AM
#69
2012 25' Flying Cloud
Moultrie
, Georgia
I just read the thread and I am in the middle of a "full monte" of a 31' Sovereign 1978 as well. I did shell on ,but shell off is a great way to go. I agree with you. I could not find very much on how to put it back on, so it led me to not take shell of. I had bought the wood for the gantrys and everything. I am very interested to see how you get it back on. I am also interested about the channeling you got from Airstream. Excellent work! I will enjoy keeping up with your progress.
06-02-2013, 10:37 AM
#70
1978 31' Sovereign
Parkersburg
, West Virginia
Flooring
06-02-2013, 10:49 AM
#71
Moultrie
, Georgia
Did you make your channeling or did you get it from Airstream?
06-02-2013, 11:24 AM
#72
1978 31' Sovereign
Parkersburg
, West Virginia
I bought it at the Jackson Center Airstream Plant. I live in Ohio so it's only about an hour or so drive.
A lot of people fabricate their own channeling, but I chose to purchase new from Airstream due to a hurried timeline and lack of a brake to bend the metal. I bought two pieces of bow channeling and roughtly 32 ft of straight floor channeling.
Things to consider if using channeling from Airstream:
On the '78 Sovereign, the original bow channel has NO lower lip on the bottom of the channel. Its basically just a U-channel bolted to the top of the floor. The new channel from Airstream has a lip so that will make it a bit of a different situation when adding/removing/changing bow channeling. Also, you will almost assuredly need to adjust the "bow" of the bow channeling.
Also, the original floor width on my camper was closer to 1/2" but the channeling from Airstream is most decidedly 5/8". I had to re-buy 5/8 flooring because the 1/2 just had too much play when fitting the channeling to the board.
06-02-2013, 11:40 AM
#73
Moultrie
, Georgia
That is definitely something to consider. I bought 1/2" marine plywood, because like you said that is what it came with. I can exchange it, but the only problem is I didn't do a shell off, however I have a good bit of channeling that needs replacing. I just wonder if I can fit 5/8" in with shell on. I think that might be difficult. It just would be nice for once to order something and just put it down and not have to make it.
06-02-2013, 11:52 AM
#74
1978 31' Sovereign
Parkersburg
, West Virginia
Shell attachment
Here are some photos of the crew sliding the frame under the shell. This part of the process was actually pretty simple. The most key part was counterbalancing the weight of the awning and door so that the shell lifts evenly from side to side. I used roughly 150 lbs of sand which was still not enough. Also, make sure its not windy; there were a couple times when we had gusts of wind so bad it took all of us to settle down the rocking.
Here is a close up of the rear of the camper. We cut the rear board to fit and slid it into place. You'll notice the rear of the frame is not original. We had to cut the rear 6 ft of the frame and fabricate as best we could. I plan on altering it to meet specs now the the shell is on.
Here is my friend John helping with the attachment in the rear.
Here is a shot of the front from inside:
Since we had to replace the bow channeling, it took some maneuvering to get the corners to fit properly. The floor was cut using the old floor as a template and since the new channeling didn't fit properly from the factory, we could only get it as precise as we could. During the deconstruction, it became very obvious that our camper was "handmade" by the less than precise rivet placement/floor cuts and various other signs of a handmade camper.
The truck in the last picture looks as if its uneven because this is in my yard and the truck is parked on a bit of an incline.
06-02-2013, 12:03 PM
#75
Tool Hoarder
West
Be careful the positioning off the shell can affect the way the windows and door seal
06-02-2013, 12:05 PM
#76
1978 31' Sovereign
Parkersburg
, West Virginia
Heres the bad side
Here is a picture of the streetside rear corner. There is too much space between the outer skin and the channeling. This will need to be fixed before I buck rivet the shell in place.
So, since we measured the rear bow channel to the rear skin of the camper and it actually lined up pretty much perfect, we ended up shaping the rear floor segment to fit the rear bow channel (which is the opposite of what we did in the front floor segment).
Initially, i thought we cut the rear floor segment too short which would create the extra space between the skin and channeling...but the rear curbside corner is flush. This makes me believe that the shell is somehow twisted a bit on the frame but I'm not sure how that would have happened unless its shape has changed a little from sitting off the frame for so long.
If anyone has any suggestions about how to fix this problem please let me know asap. I need to get this camper roadworthy so I can move it as soon as possible.
06-02-2013, 12:18 PM
#77
1978 31' Sovereign
Parkersburg
, West Virginia
@GAStreamin
Do you have a thread started detailing where you are at with your full monte?
@Marzboy
Yeah, the windows were all closed for the lift off and I double checked the seals after we set it down. I'll need to do a little work around the door to get it just right.
I did notice that the wheel well cuts on the outer skin are a little off in their placement. I'll post pictures soon.
06-02-2013, 01:37 PM
#78
Moultrie
, Georgia
Yes, I do. It is called Need Help: Where to Begin. I am not sure how to link it.
06-02-2013, 01:57 PM
#79
Tool Hoarder
West
@GAStreamin
@Marzboy
The wheel wells are probably off because the ribs that sit on top of them need to be raised and attached. Also the frame Bowes so try jacking the rear and front and see how that changes the alignment.
06-08-2013, 03:27 PM
#80
1978 31' Sovereign
Parkersburg
, West Virginia
@Marzboy - The vertical alignment is fine (assuming that the "raising and attaching the ribs" suggestion to fix alignment meant you were talking about vertically.) Its the horizontal alignment of the shell that is the issue. Whats most puzzling is that it's only on one side. The below photo is of the curbside wheel well, which is aligned correctly:
The street side skin is a little too forward on the floor:
If the shell was crooked on the floor, I'd imagine that both sides would be skewed. The rear curbside corner is also the same corner that has about an inch gap between the skin and channeling:
Thoughts?
