RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 01-27-2019, 07:32 PM   #61
wcronin4's Avatar
1978 31' Sovereign
New Smyrna Beach , Florida
Thanks Mike for the link and diagram. I am going to go with larger tanks, just haven’t figured the how yet,
wcronin4 is offline   Reply With Quote
Old 01-27-2019, 07:35 PM   #62
wcronin4's Avatar
1978 31' Sovereign
Thanks Joyflee. The original bath is okay but the tub/shower leaves a lot to be desired. Looking at any reasonable alternative which retains the current foot print
Old 01-27-2019, 09:19 PM   #63
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Me again: One of the design challenges of a rear bath as the space is a half a "sphere". The head room back there isn't the greatest.
On my old 66 Trade Wind 24' I went shopping for a fiberglass shower pan. Then I built the shower walls around the pan. The pan was two feet square, very small. And I installed it next to the wall leaving little head room. It has a hand held shower wand so I guy can get wet, lather up, and then rinse. But nothing more. Small trailer, small shower. See two photos
I might mention Airstream had a better bath layout in the 67 models. The tub went east/west crossways allowing for a stand up shower at max headroom.
It would be difficult to buy a whole shower stall and expect to make it fit; seems to me. I used standard FRP material from the home improvement stores for the walls.
My Overlander solved this headroom problem by putting the tub sorta in the middle of the bathroom. This gives the necessary head room. The tub makes a good shower pan. The bath entry door has considerable offset due to the tub.
Shower pan or tub, the thing needs room for a P trap and drain pipe under it.
This requires a support "table" about 3" off the subfloor which subtracts from headroom. See photo
I have the Inca Plastics part numbers in my shop. I'll get them to you soon. But what I chose may not work in your Sovereign, or may not be what you want. So much of black tank specifications depend on where the toilet is located.
David
Name:	1405 Bath Shower Pan-800x600.jpg
ID:	332482   Click image for larger version
Name:	1507 Bath Layout (Small) (2).jpg
Name:	1805 Bath Tub Platform (Small).JPG
WBCCI #8607
VAC Region 11
See my 1966 Trade Wind Renovation Documentation:
Knowledge Base Airstream Trailers
See my 1975 Overlander Improvement Journal:
See our 1976 Sovereign Renovation Project:
Old 01-28-2019, 07:15 AM   #64
Bauxter's Avatar
Columbus , Ohio
Tank size
Its tough to do without adding to the vertical dimension. I thought about adding spacers to my axles to allow for deeper tanks, but I never got it done
Bauxter is offline   Reply With Quote
Old 01-28-2019, 12:53 PM   #65
wcronin4's Avatar
1978 31' Sovereign
Mike - that is one of the advantages of separating the shell from the frame - frame mods should be easier. Adding three to four inches of lift was already on my list.
Old 01-28-2019, 01:10 PM   #66
wcronin4's Avatar
1978 31' Sovereign
What is FRP?
David
What is FRP, David?
Old 01-28-2019, 07:46 PM   #67
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Acronyms. I'm worse than the government. FRP is fiberglass reinforced plastic. It is a thin sheet of plastic often used in shower stalls. It's relative cheap compared to tile and other bathroom building materials. It is quite flexible. It is installed with a special contact adhesive.
My Overlander had a painted melamine bulkhead wall at the end of the tub. I stuck a piece of FRP to a piece of 1/4" plywood in my Overlander, see photo. I think it will make a nice splash backstop using the shower.
Just a note: I personally think 3 to 4 inches of lift at the axles is too much. You may have a good reason to do this, such as boondocking in the Rocky Mountains. But I think it will make your trailer look like it's on stilts. You could go out and jack it up 3" between the wheels with a floor jack. Then step back and see what you see. If you like it, then do it.
David
Name:	1806 Bath Shower Wall Installed 1 (Small).JPG
WBCCI #8607
VAC Region 11
Old 01-30-2019, 03:41 PM   #68
wcronin4's Avatar
1978 31' Sovereign
Outer Skin Finish
The following three pics illustrate the issue I have with the outer skin on Faith.
The first is on the passenger side rear and shows where a branch or a limb has been rubbing the exterior.
The second shows the uneven finish on the driver side. Apparently, this side got the worst of the exposure to the sun.
The third shows a closer pic of the another tree branch that got the driver side.
I ask the question in another thread whether the finish could be sanded with 600 to 1000 grit wet sandpaper, steel wool or another method.
The response was immediate to not using steel wool. No one commented on the wet sand option, and there was some discussion on using a fine grade of Scotch Bright.
In addition to documenting the discussion is this thread for those who may have a similar issue, I was wanting to hear from someone who may have had some direct experience with trying to fix the finish issue displayed in the pics of Faith above. Yes, I will take an inconspicuous spot and experiment but it would be nice to do something that has been proven.
Bill
Old 01-30-2019, 04:10 PM   #69
wcronin4's Avatar
1978 31' Sovereign
Update
Just returned from a week away and ready to begin work anew on Faith.
The work immediately ahead is to continue to remove interior skins, and drop the two end caps. The end cap in front is in bad condition and I am not optimistic about getting it out without destroying it. The cap is literally crumbling. The giant hole you see in the pic below is from just lifting up the bottom to test its weight.
The cap in the rear is good shape. Discolored, with small cracks at a couple of the pop-rivets but otherwise salvageable. Not quite sure how to get them down but I’m sure I’ll need help.
I have been getting some sidebar help from another forum member who has an AS the same size and model as mine. They have just within this week, used the gantry method to separate the 31 footer from the frame. So they are a couple of weeks ahead of me and they have taken the time to educate me on the process. Enormously helpful. I am hopeful that my pics and postings over the next month will be just as helpful to someone else.
I used the week while I was away to research my project and try to find solutions for problems I know I will encounter. For example, all the vista windows in Faith are damaged and leaking. The front wing windows have glass on the outside and Plexiglas on the inside. The Plexiglas is cracked in both windows but the outer glass is in good share. There is a lot of information in the window forums on how to repair, plus Robert at Vintage Trailer Gaskets has a wealth of knowledge on fixing these older windows.
Another issue that I have spent a lot of time on is researching replacement tanks for Faith’s holding tanks which are woefully too small. A lot of time spent without finding the solution. But I know more now than I did a week ago, and I am armed with the knowledge of what I don’t want.
More later.
Bill
Old 01-30-2019, 08:37 PM   #70
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
The swaying branch damage to Faith is likely repairable. Yes, wet sanding to remove the heavy oxidation is doable, however I've never done it. I would recommend using a heavy grade of Nuvite polish on a wool 8" compound pad and about 800 rpm on the polishing tool. And I would start working the area. You do have to ensure all the clear coat is removed first. Maybe stripping is in order. The Nuvite polishing method is typically very effective in restoring corroded aluminum. Read all about it at Perfect Polish if you like. Note: Polishing the trailer is one of the last jobs in the renovation.
Old plastics do get brittle. The battery box in my 75 Overlander also broke like a stale cookie. No strength left. Making a new front end cap will be a challenge and kinda fun. Some folks make wood ones, and some folks make aluminum ones.
David
Name:	1809 Battery Box Cover Brittle-800x600.JPG
WBCCI #8607
VAC Region 11
Old 01-31-2019, 06:14 PM   #71
wcronin4's Avatar
1978 31' Sovereign
Removing Interior Skins Continues
January 31, 2019
Today I am continuing to remove interior skins. I had already removed some small panels, but today I removed the center ceiling panel. That was not a pleasant experience. It is wedged into two pieces of trim (see pic) that make it nearly impossible to pull out without using a screwdriver here and there.
Here is a pic of the center ceiling section sitting on the floor.
I must confess I used some words my mother would not approve of when removing this section. And I sure wherever she is in Heaven, she will not approve of the words I’ll use when that panel is reinstalled. No one said this was going to be easy.
Ian and David highly recommended using Cleco temporary fasteners. Now that I have used them, I highly recommend them.
Here is what one looks like installed.
They allow you to remove all the rivets out of a long panel and get it ready to remove. The Clecoes are used to temporarily hold the panel in place until you are ready to remove it with help from others. The following picture shows one of the panels held in place with just Cleco fasteners.
Several of the ceiling and wall inner skins are twenty feet long in this 31 foot AS. So having these temporary fasteners is invaluable. They will also be used to reinstall the skins, and to act has temporary fasteners for patches to the outside skin. For example, I need to make patches to cover the old battery box door, the vent for the old charger/inverter, the whole left when removing the antenna and other places where obsolete attachments had been made to Faith.
Rivets
When removing the inner skins, I have learned the value of a very sharp thin chisel. As a rule, I try to drill the rivets out with an 1/8th inch bit. However, many of them spin out and there is no other way to get them out than to chisel them out. Don’t feel like you have failed if you have to use a chisel. You will learn quickly how to catch the rivet at the right angle and shear it off like a pro without damaging the skin. After they have been sheared off, you can use a punch to clear the hole.
Reassembly
As I pulled these skins down, I don’t even want to think of how I will put them back up. And I am NOT going to think about it until I am faced with the task of doing it. MY goal is to get the shell off the frame, and I am not going to be distracted by anything else until that is done. And I am ONLY dealing with those things that pertain to separately the shell from the frame and nothing else. If I get distracted by anything else, it will just impede progress.
More later.
Bill
Old 01-31-2019, 08:08 PM   #72
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Good job, except for the understandable cussing. Taking down those long, floppy ceiling panels is tough, especially working alone. Actually, I've never done it. Someday maybe.
The cleco sheet metal clamps are invaluable in holding things together. I have a set of 5/32 diameter clecos, but none of the 1/8 diameter. If I were to do interior skins someday, I will need those too. Here is a photo of me holding my plastic bath pieces together with cleco clamps while I adjusted the tambour sliding cabinet door.
I understand Airstream used the center ceiling as a "wire raceway" for the trailer, and I think for both 12v and 120vAC wiring. Do you see a bunch of wires under that center ceiling skin?
Your making good progress. Keep the Faith.
David
Name:	1811 Bath Tambor Gage-800x600.JPG
WBCCI #8607
VAC Region 11
Old 02-02-2019, 04:07 PM   #73
wcronin4's Avatar
1978 31' Sovereign
Making progress
Today I finished removing all the skins from the interior of Faith except for the two end caps and the small panels below them. In the 31 footer, the long left and right ceiling panels are about 20 feet long and awkward to handle. They were held in place by Clecos after all the civets were chipped out. I tried to figure out a way to take the panels down by myself, but chickened out in favor of calling in the cavalry for help
My son, daughter and my wife came to the rescue, and the panels were easily dropped to the floor.
In previous blogs, I have talked about trying to drill out all the rivets I could, and the ones that spun out, I would chip at with a narrow chisel. I have abandoned the drill altogether. The chisel is the tool of choice. I would have saved myself a lot of time if I had used it from the start.
I would have posted pics, but the stripped out AS with all its insulation showing has already been posted by others many times.
So far, the work has not been difficult, just tedious.
Bill
Old 02-02-2019, 04:11 PM   #74
wcronin4's Avatar
1978 31' Sovereign
Special Thanks
Special thanks to my new friend Ian. He has been an enormous help and a great resource on my project.
Old 02-02-2019, 04:46 PM   #75
Iansk's Avatar
1977 31' Sovereign
Sunset Valley , Texas
More than happy to help Bill.
Your courtesy spot is ready in TX when that thing is traveling again.
Ian
Iansk is offline   Reply With Quote
Old 02-03-2019, 03:53 PM   #76
wcronin4's Avatar
1978 31' Sovereign
First Milestone
A milestone. All the skins have been removed and the two end caps have been removed.
The forward end cap literally crumbled as it came down. I took this down without help. The rear end cap, was in relatively good shape. I had two people help with that. As I had been advised, the rear cap is not very heavy, but floppy and difficult to handle alone. With three people it was a piece of cake.
Someone asked in another thread how long it took to take down the skins and end caps. I worked several hours each day from Wednesday through Sunday. I put in roughly 20 hours on this phase.
Tomorrow I remove all the insulation and begin cleaning all the u channels. Also, I re-tape all the wires to that fell when the skins were removed and tape them up and out of the way.
More later
Bill
Old 02-03-2019, 03:56 PM   #77
wcronin4's Avatar
1978 31' Sovereign
David - question
David - on your Overlander - It appears that you used some of the original bath, and fabricated the shower. Is this correct?
Bill
Old 02-03-2019, 04:04 PM   #78
Iansk's Avatar
1977 31' Sovereign
Nice job Bill. After you get all the insulation out, bagged and disposed of you’ll really be able to identify where the bugger has been leaking. The PO of my trailer was a big fan of Olympic rivets and almost everyone of those leaked.
They look really neat when they are all naked inside too.
Ian
Old 02-03-2019, 07:36 PM   #79
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
You are well on your way with the "disassembly" of your 78 Sovereign. You mentioned you have maybe 20 hours in it so far. The vintage Airstream theorem is it take about 10x longer to put the thing back together again. They come down easy in comparison to the reassembly. However, the reassembly is the most fun. I have over 1000 hours in my Overlander and a lot more to do.
I used all of the original bath plastics in my Overlander. See photo. I did elect to rebuild the "hamper/dressing seat" gizmo popular in Airstreams through the sixties and seventies. I simply made a wood cabinet there instead. Otherwise the Overlander bath is original. See photo.
I did fabricate a shower stall in the old 66 Trade Wind I once had. It was small at 24"x24", but a guy could get wet in there. Many of the sixties and seventies trailers had a plastic bathtub with a shower over it. The bathtub makes a pretty good shower pan.
David
Name:	1811 Bath Molding Done-800x600.JPG
WBCCI #8607
VAC Region 11
Old 02-06-2019, 07:32 AM   #80
wcronin4's Avatar
1978 31' Sovereign
UBE - a new term.
As a novelist, I try to write stories about ordinary people facing extraordinary circumstances. I try to incorporate drama in the twists and turns of a plot, create insurmountable obstacles facing the hero and show how they rise up in the face of adversity.
I wish I could hype the story of Faith, my AS project, as an old man against the enormous challenge of redoing one of these relics from the past. In truth, the work has been easy, and help and advice has been abundant. This is not an “Old Man and the Sea” saga here, where Santiago fights the enormous fish. So far my work on Faith has been just that, work. And none of it has been beyond me. While I had originally seen the project as daunting, with help from friends new and old it has been enjoyable. Now Ian would say, “Wait till you get to the wheel wells” referring to one of the more challenging aspects of separating the body from the frame. I know, when I get to that phase, there will be help to get through it.
Frame issues with 70s vintage trailers are very common. Nothing I have encountered so far would have dissuaded me from undertaking this project and if your AS has similar issues, you should not be afraid to take it on. If I can do it, anyone can do it. I am finished stripping out the interior and will soon begin work in earnest to detach the body from the frame. I’m excited.
One issue that I did not anticipate is the amount of storage space taken up by Faith’s interior parts. I totally under estimated that. I have Faith’s parts scattered over two locations and my yard, hidden away from view, and it looks like a wrecking yard. What I did anticipate, and you should as well, is that having enough room to work when the body is pulled off. While I have been able to do all the work so far in my driveway, I did not want to create an eyesore for my neighbors for the two months that Faith’s frame will be out from under the shell and the body up on blocks.
Faith’s poor interior condition was evident after all the insulation was removed. All the slides used for the vista windows, which are part plastic, are crumbling and cannot be reused.
The driver side, taillight lens is pretty roached out from corrosion. I noted when I towed Faith home that the driver side, taillights were not working – mystery solved. Not sure if that housing can be repair or not.
As soon as the end caps were taken down, there was an avalanche of wires that needed to be addressed. At the factory, AS used three methods to secure the wiring harness in place. First, in all the chases down the center of the ceiling they used metal clips. In other places, where wires were run in sets of up to four to six wires they used masking or duct tape to hold them in place. In Faith, the tape used met its demise years ago. For the main cabling, they used these black cable clips that were attached to the skin using double sided tape.
On many of these, the double-sided tape had failed. Ian suggested using 3M mounting-tape. That worked great.
But there were places where the cabling was too heavy to use even the AS clips. I went to HD and scrounged around until I found these clips.
They are attached with double-sided tape, but they adhere very well. Their intended purpose is to wrap around the cable, then attached to surface. I turned them sideways and ran cable ties though them that worked extremely well. The pic below is a little out of focus but it does show how I used them.
I also made extensive use of the back of the interior skin panels to label where they came from, and how they are to be installed. It’s ugly but effective (UBE).
Currently I am working on cleaning the U and C channels and locating all the attachment bolts. In a day or so, I am moving Faith to a different location to begin to sever the body from the frame, build gantries and prepare to lift the body off. Fun!
shell off, sovereign
Frame Rust 1978 Sovereign 31" TGRIMM Repairing/Replacing Floor &/or Frame 4 12-04-2018 08:17 PM
Frame off vrs. Frame on RedRdgRnr Repairing/Replacing Floor &/or Frame 19 05-15-2018 08:31 PM
1978 31' 1978 Airstream Sovereign Land Yacht - South Florida JoshuaSteven Airstream Classifieds 0 08-12-2015 08:58 PM
can a frame be repaired without frame off restoration? RhinoWW Repairing/Replacing Floor &/or Frame 12 10-29-2014 11:46 PM
Frame off or not off... till Repairing/Replacing Floor &/or Frame 16 11-19-2003 06:20 AM
