05-31-2004, 09:04 AM
replacing roll up doors
I need to replace one of the roll up doors under the front couch. Any hints? Thanks
camphost
05-31-2004, 10:31 AM
1968 22' Safari
1976 27' Overlander
Newport
I have the overhead tambours.... will they fit
They are laying all around my garage, until I can get them on ebay...
Get me measurements.....and I'll see what we can work out.
Ron
They are the off white colored on each side of the picture... The color may be a problem, but happy to help if I can
Ron ... now in Newport, Washington
[font=Impact][font=Arial Black]
07-21-2013, 01:30 PM
2014 27' FB International
Payson
, Utah
I replied earlier that roll doors can be purchased from inland rv @ inlandrv.com they have it listed at $595.00 for a 4 foot by 8 foot roll or $21.70 a foot. Does anyone know of a less expensive place to buy, or is this a really good price, I know that it is expensive but this is gold prices.
07-21-2013, 02:40 PM
1981 31' Excella II
New Market
, Alabama
Keep and eye out on here and someone will probably give you some that will fit or you can cut down.
Perry
07-21-2013, 03:16 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
That is in the ball park. I suppose it you had to you could make your own or source from a woodworking company.
Aaron
WBCCI #XXXX AIR #2495
07-22-2013, 05:59 AM
1981 31' Excella II
New Market
, Alabama
The think is that the tambour you buy is real wood but the stuff in your trailer is the fake plastic stuff. That is probably the main difference that it costs so much. Also it is probably not made in China like most stuff is.
Perry
07-25-2013, 08:58 PM
Payson
, Utah
Ron
much appreciated The tamber in my doors are probably walnut brown, many of them are still good would like to keep it uniform.
07-25-2013, 09:05 PM
Payson
, Utah
Many of my tambour doors are still good they are walnut or some dark color like that would like to keep them uniform, thanks for trying Jim
07-25-2013, 09:29 PM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
When I had the Tambour doors restored in my 1978 Minuet, I sourced my new Tambour from Tape-Ease. They have a large selection of tambour materials to select from including: I was replacing the off-white vinyl tambour in the upper cabinets in my Minuet. Since the vinyl didn't hold up well to the summer heat while stored, I chose to go with birch veneer tambour and stained with a white-wash stain that resembles the original, but with a richer, more elegant feel.
Good luck with your investigation!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
04-18-2020, 08:49 PM
airstream junkie
1971 27' Overlander
1971 31' Sovereign
1974 21' Globetrotter
Atlanta
, GA
[QUOTE=tin can luv;100905]They are laying all around my garage, until I can get them on ebay...
Ron
Do you still have any left? I know that your post is old but just checking... thanks, Lawrell
04-18-2020, 09:32 PM
1977 Argosy 24 Rear Door
Chesapeake
, Virginia
[QUOTE=lawrell;2352407]
Ron
Lawrell,
I have a couple doors. What size do you need?
Jeff
04-19-2020, 10:47 AM
airstream junkie
1971 27' Overlander
1971 31' Sovereign
Atlanta
, GA
[QUOTE=ArgosyJeff;2352413]
Originally Posted by lawrell
Lawrell,
Jeff
Hey Jeff and Ron,
Thanks for getting back. I'm an idiot, I have the original doors (I packed up the 'parts' from the guy I bought thr camper from and just checked it) but I do need the roll up track that goes between two roll up doors. Not sure if it matters but this is for the compartment above the kitchen in a 77 25' trade wind.
Thank you
Lawrell
airstream junkie
1971 27' Overlander
1971 31' Sovereign
Atlanta
, GA
Ron
Hey Jeff and Ron,
Thank you
Lawrell
04-20-2020, 07:03 PM
Chesapeake
, Virginia
[QUOTE=lawrell;2352539]
Originally Posted by ArgosyJeff
Hey Jeff and Ron,
Thank you
Lawrell
Lawrell,
Let me look tomorrow, I'm sure Ive got what you need. I'm renovating a 77 Argosy and I'm not using anything that I removed other than bath components.
Jeff
05-29-2020, 08:10 PM
DRJJL
1985 31' Sovereign
Poway
I have a 1985 with the original vanilla “sponge painted” interior with the tambour doors. I am planning to replace all the tambour material with bamboo mats which I will cut and spray-paint to a rose gold color to match the pulls. I have the tambour removed, but now I see the pulls have teeny tiny nail heads on the back going through the aluminum into the fabric but not through the other side. Not wanting to break or bend these pulls; need a very thin clipper tool to slide between and clip the mini micro nails. Any thoughts or experience???
drjj
