RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 07-15-2013, 03:11 PM   #1
astrocaver
1986 25' Sovereign
Denver , Colorado
Refrigerator pilot light
Can't keep mine on while driving. Is there some kind of shield I can build or close off part of the vent? I am headed for some hot weather and fear for my ice cream.
astrocaver is offline   Reply With Quote
Old 07-15-2013, 03:17 PM   #2
DKB_SATX's Avatar
Alamo Heights , Texas
I had this problem when I first got the '75 Argosy. I found that the gas pressure was lower when only the refrigerator was on than the spec for when half the appliances are running. I got a new regulator and now my refrigerator stays lit.
If you measure the gas pressure and find that it's OK, and the burner and flue of the refrigerator are clean, you can then try managing the airflow through the fridge locker with an air filter or something, but the bottom-inlet/top-outlet setup is pretty good most of the time.
— David
Old 07-15-2013, 03:59 PM   #3
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
Yes, same thing happened to me. When I was at JC, they adjusted the regulator because the pressure was too low, and they fabricated a wind- shield out of sheet metal.
Problem solved, not sure if I even needed the shield
Hiho Silver is offline   Reply With Quote
