RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-02-2019, 12:34 AM   #1
No spare tire in my 1984 sovereign
Hello all.
I just bought my 1984 AS 27D recently. I’m very Excited...and lots work to do. I do have a few questions, much appreciate if someone can help:
1. No spare tire under the front tongue behind propane tanks.
2. And the propane line is crossed/pinched by the jack. Is this normal?
3.there is a button with “STEP” right beside the door (inside). don’t know which light it controls.
4. Fridge doesn’t work. Need to find out why.
5. Is it normal there are some insulation materials fall out from the ceiling AC unit?
Thanks so much!
uahub is offline   Reply With Quote
Old 11-02-2019, 01:10 AM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Welcome to the forum.
Hi, although I have not used a spare tire for decades, I would not be without one. Propane lines should not be pinched. I'm sure someone with a similar trailer to yours will chime in.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 11-02-2019, 06:56 AM   #3
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by uahub View Post
Hello all.
It would be a good idea to get a spare tire and wheel, and check the other tires at the same time for condition and age.
No. The LP line should not be crushed. It probably got that way when the tongue jack stopped working, and someone used a jack or jackstand to support the tongue. The line will need to be repaired or replaced.
The step light, of course. Located outside the trailer, near the steps.
It could be almost anything. Is it plugged in? If the LP line is crushed, it probably won't work on LP (duh!). Is it the original? Has somebody replaced it with a household fridge?
Not really normal, but that's where mice seem to like to make nests.
Thanks so much!
You're welcome.
Old 11-03-2019, 12:27 AM   #4
Thanks for your reply. I’ll get a spare for sure. The LP line was pinched by the jack stand/support near the door, not near tongue jack. Looks like original though.
Old 11-03-2019, 05:53 PM   #5
Bompagene
Bompagene's Avatar
Las Vegas , Nevada
Step switch
On my 1979 the ‘step ‘ light is above the door.
Bompagene is offline   Reply With Quote
Old 11-04-2019, 10:24 AM   #6
1976 31' Excella 500
Chappell Hill , Texas
Quote: "Is it normal there are some insulation materials fall out from the ceiling AC unit?"
Are you sure it's not the air filters coming apart?
tbashin is offline   Reply With Quote
Old 11-04-2019, 11:24 PM   #7
I didn’t even know there is air filter. How do I change the filter? Thanks
Also the tongue jack decided to only go up not down today vintage AS sure is an endless project with fun though.
Old 11-06-2019, 08:31 AM   #8
Depends on your model but the ceiling unit has reusable/washable air filters at the return air inlets.
They made have degraded to the point they are coming apart. If so you can look for new replacements or use any type of air filter media you get at the big box stores but you need to make sure it is backed by plastic or wire screen to keep it from sucking in. You could even use scissors on a home filter and cut to fit.
sovereign
1984 Airstream Sovereign double :: 1984 Airstream Sovereign EaglePeakAir Airstream Registry Discussions 0 01-03-2016 11:03 AM
Need a soft tire cover for front-mounted spare tire! Bessie1968 Tires 10 05-10-2013 11:05 PM
16" spare tire vs OEM spare tire rack Bluto Wheels, Hubs & Bearings 22 04-30-2013 06:13 AM
Spare tire cover for 1984 310 series rawroadie Exterior Restoration Forum 1 02-03-2013 02:55 PM
Lost spare tire panel 1984 Classic mapsight General Motorhome Topics 2 10-31-2005 09:35 PM
