12-01-2011, 02:24 PM
1987 25' Sovereign
Punta Gorda
LED Tail Lights
Does anyone know if LED tail lights are available for an 87 Sovereign or any that can be modified to fit
12-02-2011, 02:19 PM
1985 25' Sovereign
Plant city
My neo got some for his 85 25ft and if the trailer is anything alike then yeah
12-02-2011, 02:39 PM
1971 27' Overlander
Central
, Ohio
12-02-2011, 03:59 PM
1969 27' Overlander
Albuquerque
, New Mexico
Check with Inland RV. They have L.E.D. replacement lights for most AS models.
Ed Glenn
12-02-2011, 05:17 PM
Liberator
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie
, Alabama
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
12-02-2011, 06:35 PM
2016 25' Flying Cloud
Sunnyvale
There is an easier way.. Several places sell cylindrical red LED bulbs equivalent to 1157's, which fit in tail light receptacles, and have two contacts and two levels of brightness.. Polishing the reflector or lining with foil makes them even brighter... Only red LED bulbs will be cvisible throgh taillight lenses, and only amber will light up through side marker light lenses, according to other experts here... Superbirght LED's has a large selection of 12V vehicle bulbs for exterior lighting. Not so sure about interior lighting..
Condoluminum
12-02-2011, 06:40 PM
1999 25' Safari
Denver
Also LED4RV is a great place to get all the LEDS you need.
Jim D.
AIR # 56543 TAC# CO-10
12-02-2011, 06:43 PM
Corpus Christi
nice
Check this thread I started a while back. We have a 1984 Sovereign. Got mine from S&S LED's. Pic on the last post. And here is another pic. They work really well, and I am ok without the red border around the backup lights.
http://www.airforums.com/forums/f447...e-83527-2.html
Chuck & Skye
Rock and Roll Will Never Die!
WBCCI 3805
AIR 54011 Since July 2011
12-02-2011, 08:12 PM
1985 25' Sovereign
Plant city
Those should work
12-03-2011, 04:17 AM
1987 25' Sovereign
Punta Gorda
Thanks for all the great info I think I am going to wait till they re stock the kits and go that route
12-03-2011, 05:52 AM
Corpus Christi
Pics! We "require" pics when you are done.  You will hate yourself if you do not do before, during, and after shots. I always have good intentions, but then get busy with the job and forget that the "during" pics are worth bunches to people down the line!
Enjoy the fun.
Chuck & Skye
WBCCI 3805
12-04-2011, 08:53 AM
Denton
, North Carolina
replacement kit
Originally Posted by Ganglin
This kit has been modified to a sealed light kit.
LED-kit2
Dan Brown Denton NC
12-04-2011, 11:42 AM
Corpus Christi
Joshua,
I went to the site you pm'd me and then checked measurements against the old ones that came out. I think those will be too big for you. But the ones posted right above this look good. Especially if they are now a sealed kit. Not sure about the plug on the end of the wires, I had nothing like that behind mine, it was wire to wire splice.
Here are the pics with my old ones so you can check measurements. Depth was fine, but I think the lights were simply bigger.
Chuck & Skye
WBCCI 3805
12-04-2011, 06:28 PM
1987 25' Sovereign
Punta Gorda
Enjoy the fun.
Lights have been re stocked and mine are in the mail ETA Wednesday
12-04-2011, 06:43 PM
Newton
Joshua,
Thanks Casa for your help, you are correct the lights I was looking at are to big.
But I ordered the above mentioned sealed kit from Dan's LED4RV.
So Im good to go! Ill report back around Xmas when I get home and there installed. Looking forward to seeing the difference.
12-20-2011, 06:38 AM
1987 25' Sovereign
Punta Gorda
Enjoy the fun.
Got the kit from LED4RV Dan his site has pick's tht leave nothing to be desired. Only thing I did was goop the spacer to the lens before I installed it to make a gasket otherwise they take about 10 minutes to install & they are super!
12-20-2011, 08:13 PM
Corpus Christi
Nice...gotta agree, that is where I got all the clearance lights.
Chuck & Skye
WBCCI 3805
07-28-2015, 10:57 AM
1987 29' Sovereign
Huntsville
, Alabama
Just put the same kit from LED4RV on my 87 29ft Soveregin,replaced the lens a well,took about 15 min per side, look eally good and is much brighter.
Dan responed quickly and made sure the kit would fit.
07-30-2015, 08:49 PM
Denton
, North Carolina
led-kit replacement
erikk
The LED-kit1 has been replace by the LED-kit5
The LED-kit5 is a much better light kit. It is water tight, brighter and much easier to install.
Dan Brown Denton NC
