08-27-2009, 06:28 PM
Ricko
1985 25' Sovereign
south berwick
, Maine
Help With VIN #
Help!! can anyone decipher my VIN #. I have searched and searched and no matter what I do, things just don't match up.. Any help will be greatly appreciated.. # 1STBBAJ2OEJ502695
Rick..
Just So you know, I own a 1984 sovereign 25 ft center bath, rear double.. Now, after researching a little, Airstream does not show a 25 foot sovereign being manufactured.. Only in 1985??? The tag states that the Sovereign was manufactured 6/84.
08-27-2009, 08:02 PM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
Help With VIN #
Greetings Ricko!
Originally Posted by Ricko
1STBBAJ2OEJ502695
I believe that your VIN decodes as follows: - 1ST = Airstream Travel Trailer
- B = Corner Rear Bath Modern Design
- B = Classic
- A = Semi-Monocoque 96" narrow body, continuous curved, shiny aluminum shell, ontoured window glass, frames, and doors.
- J = 25' to less than 26' feet in length
- 2 = Double Axle
- O = Unique Check Digit
- E = 1984
- J = Jackson Center, OH production center
- 502695
I base this on a document that I have in my files from some time back. A copy is attached to this message.
Kevin
Kevin D. Allen
AIR #827
08-27-2009, 08:38 PM
Ricko
1985 25' Sovereign
south berwick
, Maine
Thanks Kevin, I really do appreciate the info. The Problem with the VIN, is it is a sovereign, not a classic and a center bath with a rear double.. "BB" in the VIN is the confusing part for me and the fact that Airstream, from my research, did not manufacture a 25 ft. Sovereign until 1985.. But my Vin states "1984" LOL why is it that every time I do research on Airstream, it's like playing detective..LOL.. Again, Thanks again for the info..
Rick
08-27-2009, 09:39 PM
Moderator Emeritus
1964 26' Overlander
Anna
Help With VIN #
Greetings Rick!
Rick
With a production date in June of '84 could very well translate into a pre-production 1985 model as Airstream usually has their "next-year" models ready for display at the WBCCI International Rally that runs from about June 25 through July 5 each year. It is possible that it may have been an early test coach for the '85 Sovereign explaining a VIN that isn't entirely consistent with the coach. Stranger things have happened in the Vintage Airstream arena.
Kevin
Kevin D. Allen
AIR #827
08-27-2009, 09:41 PM
San Angelo
I've seen guys swap VIN tags on cars...is it possible this was done to yours? IIRC, isn't the VIN stamped somewhere on the A-frame too?
Just an aside, my '89 Jag had the VIN in 10 different locations.
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
08-27-2009, 10:41 PM
Ricko
1985 25' Sovereign
south berwick
, Maine
Thanks Kevin..
Kevin
You most likely are correct in your assumption, the trailer could be a Pre Production Model.. it has the 1984 Sovereign Lettering and the Side decals are smooth vice raised as in the 1985.. It also has two porch lights, one on each side of the entry door..with which looks like, the original interior switches.. I will continue on this journey I have started for myself.. and hopefully I will be able to find the evidence to determine it's beginning.. But we will See..LOL.. again Thank you Kevin for all the Help..
Rick
08-28-2009, 01:07 AM
Moderator Emeritus
1964 26' Overlander
Anna
Help With VIN #
Greetings Rick!
I just took a look at the beginning and ending sequential numbers for 1984 -- the last four digits of the ending number for 1984 was 2727 -- according to this, your coach would have been among the last 32 coaches (of all sizes) produced for that model year. This information is available at this link.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Another help with VIN #
Jeff3298 |
Title, VIN & Registration |
2 |
12-07-2008 11:49 PM |
help with vin #
TJBrigade |
1 |
10-19-2008 09:26 PM |
Vin ID
JBK |
6 |
11-20-2006 08:00 PM |
Vin # Help!
pfay |
23 |
01-19-2006 06:16 AM |
VIN Help
Stinky |
0 |
11-12-2003 04:13 PM |
