RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 03-07-2003, 05:34 PM   #1
Jenturnr's Avatar
2006 34' Classic S/O
Hobe Sound , Florida
Countertop edging
Countertop edges in my 86 Sovereign are cracked/dry-rotted. Airstream cannot get replacements. They are cream colored, about 3/4", with a thing in the middle of it that pushes into the outer edge of the counter top. Anyone know where I can get a replacements?
Jenturnr is offline   Reply With Quote
Old 03-07-2003, 06:32 PM   #2
Welcome to the forum!
Try these:
http://all-rite.com/trimmoldings.html
http://www.tapeease.com/t-moldin.htm
3/4" or 13/16" will probably work.
Good luck!
63flyingcloud is offline   Reply With Quote
Old 03-08-2003, 07:08 AM   #3
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 122
The plastic stripping can be replaced fairly easily. I took old plastic vertical blinds (the type that cover sliding glass doors) and trimmed the plastic to the correct width and slipped it in. It is tricky, but it can be done. I took out my entire countertop and resurfaced it with white formica, then used a spray paint on the edging that is aluminum finished. Then I put the stripping back in. I think it looks great.
Barry
72 Overlander
92 GMC Suburban
http://web.tampabay.rr.com/bfrankli/airstream.htm
Sneakinup is offline   Reply With Quote
Old 03-08-2003, 07:32 AM   #4
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I used Formica Laminate
It takes over 8 feet, and laminate only comes in 8 foot lengths. It is a tight fit, but can be done.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 05-19-2004, 01:56 AM   #5
JoeCal's Avatar
I've seen something that might work at either a lumber center or a furniture builder supply house. It's used to cover the edge of plywood. You cut a groove in the plywood and glue/push the molding in. Can't name a precise source, though.
JoeCal is offline   Reply With Quote
Old 05-20-2004, 09:34 AM   #6
Jenturnr's Avatar
86 Sovereign
Thanks JoeCal for the info. We did find some edging material at a lumber store that just sticks on. It worked quite well. We have since traded our 86 for an 02. We are excited!
Thanks again!
Anyone know what this is pdxor97225 Our Community 7 01-27-2004 09:58 AM
aluminum composite countertop repair? Janet H Cabinets, Counter Tops & Furnishings 1 09-30-2003 10:38 AM
New Countertop smily Cabinets, Counter Tops & Furnishings 38 07-01-2003 07:16 AM
Door edging Pahaska 2002 - 2005 International 0 06-26-2003 03:24 PM
