Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1984 - 1989 Sovereign
Old 10-31-2002, 12:37 PM   #1
Wink '85-34ft Sovereign City Water Hook up
1985-34 ft Sovereign - Need to replace or repair the the City Water hook up. We have a leak. Very finen small crack. Does anyone have answer to fixing or replacing. Would like to stay away from cut hole in side of trailer. But this maybe the only answer. Would like to buy the elbow.
E&T Stutts is offline   Reply With Quote
Old 10-31-2002, 06:31 PM   #2
If you are talking about the brass elbow that recieves the brass body, I see that the one I took off my '85 Sovereign is cracked as well. This is undoubtedly the fate off all these plastic pieces from that era, as is the reason so many of us I replaced the grey plastic plumbing.
I went with the "hole in the trailer" method, and really think it is an improvement. If you must have one, however, there is likely one still on an '86 Sovereing at Colaws RV Salvage - http://www.colawrvsalvage.com/
Mark
j54mark is offline   Reply With Quote
Water coming out city water inlet mutcth Fresh Water Systems 7 11-02-2021 03:31 PM
City Water Connection gaylejoe Fresh Water Systems 10 04-13-2015 12:59 PM
Water Heater Calcium Deposits -- What to do? roscher Water Heaters, Filters & Pumps 7 05-18-2011 03:11 PM
Locating new city water inlet Globie64 Fresh Water Systems 12 03-10-2011 08:55 PM
