Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Excella > 1987 - 1989 Excella
Old 06-07-2021, 06:00 PM   #1
1987 32' Excella
Barnesville , Georgia
Small plastic water tank next to freshwater pump
Exploring new to me 87 Excella 32’. While tracing water lines before energizing, I pulled up the floor of the closet and see the pump and adjacent to it is a small rectangular plastic tank. Water line from the pump appear to be plumbed into the tank. Any ideas? Looks original..
1987 Excella ( current)
1971 Excella, (sold), 1973 Excella (sold)
1988 34’ Limited (sold)
2016 Redwood 39 MB (Fulltime in this one)
2001 Carriage LS (part timer at lake Sinclair)
High-pockets is offline   Reply With Quote
Old 07-04-2021, 11:13 AM   #2
1987 32' Excella
No replies but I think it was/is a winterization system
Old 07-04-2021, 11:25 AM   #3
2020 23' Flying Cloud
2019 22' Sport
Sebastian , Florida
How plumbed?
If the pump goes to the tank (and it is a sturdy, sealed one) it may be an accumulator to dampen out the pulses from your diaphragm pump.
If the line goes from the tank to the pump, and there is access to add chemicals, then it is there for winterization purposes.
GetawA-S is offline   Reply With Quote
Old 01-07-2022, 05:49 AM   #4
1987 32' Excella
Thanks, I bite for winterization, thank you
12v Pump to pump water from auxiliary cans into freshwater inlet? blacklab Boondocking 26 07-27-2022 01:45 PM
Newbie question - broken plastic freshwater fill hose ? Slmurdoch Fresh Water Systems 8 07-12-2019 12:39 PM
Secondary Freshwater Tank or Convert Grey/Black to Freshwater LiamG Waste Systems, Tanks & Totes 24 01-13-2019 07:55 PM
What glue should I use to fix a small crack in my freshwater tank? JimGolden Fresh Water Systems 4 06-11-2009 04:22 PM
freshwater tank hole.......material and plastic weld kits... leefields Fresh Water Systems 4 02-06-2006 06:44 AM
