Old 08-25-2017, 05:57 AM   #1
Fr Jeff
frjeff's Avatar
1989 29' Excella
Oscoda , Michigan
Hensley Hitch with Ford Back-Up Assist
Will these two get along with each other? Just wondering as the Hensley does not pivot on the hitch ball but within its head mechanism.
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
frjeff is offline   Reply With Quote
Old 08-25-2017, 04:40 PM   #2
Reads a lot
Titusville , Florida
Hi frjeff, I don't have a Ford but I do have the Hensley hitch that I use with my 2500 RAM. I haven't had any problems hitching or unhitching. The back up camera makes hitching up alone very easy, well, easy after a couple of days of practice lining everything up. Now it only takes a few moments to get the job done.
Hope that helps.
Lauri
She Believed She Could so She Did.
kendrick.l.j is offline   Reply With Quote
Old 08-25-2017, 05:39 PM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Ford has several "interesting" camera setups. Some are more useful than others. I find the basic backup camera *very* useful for hitching up. It will work with any hitch. It takes the solo hookup process from a "good grief" thing to a "no sweat". The "backup assist" stuff ... not so much. I find that there are just to may odd things in a normal campsite. (How close is that tree, where is the sewage, how close to the pad ... ).
Old 08-25-2017, 06:05 PM   #4
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Father Jeff, I don't think it will work reliably. The extra pivoting in the Hensley will probably give the Ford system an electronic headache.
Old 08-25-2017, 08:17 PM   #5
white laker's Avatar
2008 34' Classic S/O
lanark , Ontario
It may not work properly. so...... keep the Hensley and trash the Ford!
Just kidding.... It may mess up the way the backup system gets and deals with sensor information. Try hard to keep the Hensley. Pete
Pete Crook
"Put it all behind you!"
S/OS#88
WBCCI # 8160
white laker is offline   Reply With Quote
Old 08-26-2017, 04:19 AM   #6
Reads a lot
as I stated earlier I don't have a Ford, why would the backup assist fail just because of the Hensley? Wouldn't it fail with Blue Ox, or PP or other WD/anti-sway? Is there any way to turn off extra stuff and just use a basic backup camera?
I am not interested in starting another thread of Truck Wars. I have only own the RAM and Hensley so I am asking out of ignorance and want to know why it wouldn't work. Thanks
Lauri
Old 08-26-2017, 04:57 AM   #7
1993 21' Sovereign
It may well not work because the Hensley and PP have an extra pivot point in the system, which may confuse the program.
Old 08-26-2017, 05:24 AM   #8
Lakes Region , New Hampshire
Why shouldn't it work? We're talking about connecting the truck to the trailer correct? If so, the setup for the system is when connected you attach the black/white sticker to the frame and then the computer recognizes it's location and always puts it in the same spot.
It doesn't care about pivot points or anything else, it just locates the ball head in reference to the sticker.
When I first read it, I thought people were referencing the backup camera and connecting the trailer and how easy it was, this my previous thoughts.
As for backing assist with trailer attached, I do not have a Hensley, but I would not think that it has an "extra" pivot point, but just an extended one and as such should not have any issue with the system, as you input the measurements into the system.
Here's a good video of the system
ttps://youtu.be/e9c9P_kLrU4
RandyNH is offline   Reply With Quote
Old 08-26-2017, 05:40 AM   #9
1993 21' Sovereign
I guess I oversimplified my explanation.
A Hensley Arrow, or Pro Pride Pivot Point Projection System has a pivot point that rotates in a circle. It is not a fixed, single position point. How do you think a computer would react if it started maneuvering based on a fixed pivot point, and suddenly that pivot point moved 6 inches to the left? Then back 6 inches to the right, as the truck and trailer backed up?
Old 08-26-2017, 05:51 AM   #10
Thanks, I looked up the working video, I see what you mean and didn't realize they had such a pivot rotation. The nice part to the backup assist is that you can direct it's movement with a small dial on the dash, as opposed to having to use the steering wheel, with just a left/right flick of which direction you want it to go.
Old 08-26-2017, 07:49 AM   #11
Half a Rivet Short
Hi
The Ford setup has a bunch of measurements that you put in. It also has a visual "target" sticker you put on the trailer. The big issue is getting that sticker inside the view of the camera. Since different vehicles mount the rear camera in different ways, I'd bet that results on one vehicle may not translate to success or failure on a different model.
Old 08-26-2017, 08:21 AM   #12
truxpin's Avatar
2001 34' Limited
Tucson , Arizona
I'd put a call into Hensley's tech guy (Terry, I think) Of course they know their hitch frontwards & backwards and may have a good answer for you. I think the Ford backup assist has been around long enough that they might have had a chance to do some live testing of their own.
2013 Ram Power Wagon 2500 4X4 5.7 Hemi
2001 Airstream '34 Limited
Hensley Arrow
Fulltime in 2013 and LOVING it !!
truxpin is offline   Reply With Quote
Old 08-26-2017, 02:28 PM   #13
Off-we-go's Avatar
2007 19' Safari SE
Marina , California
Thumbs down
I have both the ford backup assist and a hensley cub and they do not work together.
Off-we-go is offline   Reply With Quote
Old 08-26-2017, 02:35 PM   #14
2017 23' Flying Cloud
Seattle , Washington
Ford back up assist
I believe if you look through the forms you will find a thread on the subject .
Another individual had the same problem . Any measurement from the hitch ball had to be taken to a different spot .
Raincity is offline   Reply With Quote
Old 08-26-2017, 02:46 PM   #15
Fr Jeff
frjeff's Avatar
1989 29' Excella
Oscoda , Michigan
Agree with all comments with thanks. Part of the problem is finding where to accurately place the required decals (and, having space to put them, even if you could figure out the measurements).
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
Anybody have experience with Ford's New "Pro Trailer Backup Assist"? DaytonaDan Towing, Tow Vehicles & Hitches 35 10-07-2017 05:03 PM
Ford's Pro Trailer Backup Assist BW1 Tow Vehicles 10 09-17-2017 06:43 AM
Ford F-150 Back Up Assist Setup garylind Tow Vehicles 1 07-04-2017 02:59 PM
Ford's Pro Trailer assist sroach Towing, Tow Vehicles & Hitches 2 01-12-2016 08:11 AM
Ford Dynamic Hitch Assist cwf Towing, Tow Vehicles & Hitches 2 12-12-2014 04:52 PM
