Old 06-04-2018, 06:50 PM   #1
Fr Jeff
frjeff's Avatar
1989 29' Excella
Oscoda , Michigan
Hensley Hitch Set-Up
AS is an 89 29’ Excella
Tug is a 206 Ford F-150 SuperCrew Eco with Max Tow.
Newb with this hitch.
Can anyone with a similar setup (truck and trailer) share with me what stinger bar you are using?
Mine came with a 4” and a 2”, but not sure I am using the appropriate bar.
With the 2” upward it seems to not allow much WD tension without raising the tongue. With it downward, seems to need too much tension to level the tug and trailer.
Maybe I need the straight stinger bar?
All help appreciated.
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
frjeff is offline   Reply With Quote
Old 06-04-2018, 07:40 PM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
What is the height from the ground to the inside top edge of the 2" hole in the receiver? And what is the height from the ground to the top of the coupler of the Airstream?
Old 06-04-2018, 07:51 PM   #3
Haulin8or's Avatar
2018 25' Flying Cloud
Woodstock , Georgia
Well, I have a Excursion and the measurement from the ground to the bottom of my receiver is 17”. I use a 2” bar in the drop position. Mine is very level.
Greg & Colleen | Zach, Sidney & Robert | Bear the Collie
2018 Airstream Flying Cloud 25FBQ w/Solar | Hensley Arrow
Tow Vehicle - 2004 Ford Excursion Limited PSD 4x4
Haulin8or is offline   Reply With Quote
Old 06-05-2018, 03:53 PM   #4
Fr Jeff
frjeff's Avatar
1989 29' Excella
Oscoda , Michigan
From ground to inside top of truck receiver hole = 20”
From ground to top of Hensley bar coupler = 11.5”
From ground to top of AS coupler hole = 18.5”
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
Old 06-05-2018, 07:22 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Just what we did....👍
I measured from the top of the coupler with the trailer level.
Then got a stinger that measured the same from the top of the ball. In our case the drop when hooked up was returned to level with WD set.
TV & trailer level when loaded for Camping.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."Molly Ivins
“Growing Old…being able to think about the things you can no longer remember.” RLC
"Never tow faster than your Guardian Angel can Fly"
Tahawus....🌥
Hensley Hitch 4" hitch bar to trade for a straight one StreaminGuy Airstream Classifieds 0 10-20-2015 08:03 PM
Top Rated Sway Control Hitch (Hensley Hitch) Dgresham Airstream Classifieds 0 08-27-2014 10:20 AM
Questions on hitch set set up for my Dodge Astriking Hitches, Couplers & Balls 13 04-25-2011 05:03 AM
To Hensley or not to Hensley Aquabud Hitches, Couplers & Balls 86 12-22-2010 08:10 PM
